Google works much better when you spell Tokin correctly: Tokin SIT DEFiSIT musings
Ok. Is it possible to build the DefiSIT with Token?
yes, SissySIT is exactly that
Ok. Is it possible to build the DefiSIT with Sony??
yes, SissySIT with some changes (Ugs large!), but why, when Tokins are available
Ok. Is it possible to build the DefiSIT with tokin thf-51s?
ZM forgot I have a pair of SJEP120R100 from PA are better ?
DEFiSIT (my spelling) uses the depletion mode Semisouth part - SJDP120R085, not the enhancement mode part that all the other amps use (SJEP variants).
If you are blessed with SJDP parts then you have a chance to build Papa's flavor.
HI ,difference then power ?My SissySIT R.3 is part of an audio system that produces beautiful music.... My Sony VFET lottery amp keeps my car from rolling off the ramps when I'm underneath changing the oil.... (all in good fun..)
That probably helps with my "unsuitable" speakers. I assume it has more to do with the DEF output stage than anything. More vibrant, more spooky, more texture, more interesting, more realism, more fun, and some other "more" words I can't think of right now. How's that for a review?
DEFiSIT** may be made with SJDP, but Real McKay is made with Papa's SIT-1 part, same as all SIT-3 amps
though, whoever is having SJDP by chance, I'm interested to buy a pair, to try it in SissySIT - it'll fit as glove
**read - SissySIT
that's proper!
real Greedy Boy is having (at least one) Papamp in every room
that's proper!
Bathroom included?
I have had problems with noise with every amp I have owned, until I got the V-fet P-channel amp. I think it is because of external brick, or maybe NP's noise filter for said brick. I use V-Fet for the two pairs of horns: Renault Garcia-Fons - Fortaleza. FaitalPro 15PR400 8ohm, 80-270Hz, Xindak 100W September 19, 2021 - YouTube
- SissySIT R.3
