This is a great effort in balancing the use of materials with results. Thanks to all.
Would I lose "style points" if I chose to make the side panels (or the whole thing) from 3/4" stock?
Would I fall out of the category for using corner blocks (3/4" x-section) throughout?...even if I robbed them from the scrap pile?
I don't see why 5/8" or 3/4" for that matter would hurt. If you change the thickness of the inner boards, preserve the first couple flares cross sectional area, and allow the thickness of the plywood to encroach into the larger areas. Use PL polyurethane construction adhesive only. You won't need corner blocks, PL expands into the pores of the wood and seals better than anything else I've seen. You will literally separate the plys of the wood before you make the joint fail.
mm
Hi martinsson,
Just for you the drawing with notes in mm. 🙂 Hope you'll check my numbers.
Regards,
Hi martinsson,
Regards,
tb46, thank you ever so much, this i did not expect : )
I will be sure to give it a good long look at within short.
I like the design alot, the fact that it is compact and high preforming will appeal to the pro's, and it will not hurt ordinary people either, this combined with the well thought out economics and simplicity of assembly makes it a winner in my book this far, and it makes me want to know more about it.
My initial concerns are the previously stated cabinet flexing, especially in the mouth area, in this perticular regard i like my own desing better.
other then this, marvelous !
Use PL polyurethane construction adhesive only. You will literally separate the plys of the wood before you make the joint fail.
Absolutely, screws are something you use a few of as clamps till it sets. I switched to it back when it first came out decades ago and the local band/PA stuff I (re)built were like Timex watches 😉 (and may still be for all I know) except for the ones that fell off moving vehicles or from a great height, though even then the seams remained intact, shearing/bursting some distance from them. The downside is that what I used was fairly noxious if used in-doors and literally a pain to get off skin. Hope current versions are more user friendly.
GM
martinsson:
What I assumed was cabinet flex on my initial 28v readings, was soggy ground and rain robbing 2db. The next days tests were as expected on my driveway. Also a steel grill will prevent any vibration at the mouth.
GM:
The current PL doesn't stink, but once on your hands -- is there for the duration.
GM:
I know this goes against the intention of this design, but do think this could be made to play lower using more wood? 🙄
Also might of missed it, but did was this built from 15 or 18mm wood?
Cheers
Cheers
"this could be made to play lower using more wood?"
Of course, how low do you want to go?
"was this built from 15 or 18mm wood?"
12.7mm (1/2").
12.7mm (1/2").
could one get 20 to 25Hz from three 8*4 boards for two speakers? i.e. 1.5boards each. And fit through a 2'8" (812mm) doorway?
build the big box then... 2 sheets 3/4" ply -- easily hits mid 30's with authority.30-35hz would be good! 😀
http://www.diyaudio.com/forums/subwoofers/127908-jbells-set-four-tapped-horns-4.html#post1598913 Or even build labsubs....
The goal here was specifically the best output in a single sheet, that I could easily build for the church's/schools that I do installs for. The entire reason for a single sheet, was primarily weight driven. If you limit yourself to a single 42lb auroco sheet of plywood, you are pretty much guaranteed a 50lb cabinet with a 3015lf installed. Finding a pack friendly and attractive size was a side bonus.
The real benefit of this last design, is I finally have a sound similar to the fury box, in a quick/simple box build. I'm beginning to see folding of TH's like hitting keys on a piano. The more dimensions that line up, the more it's like hitting octaves of the same note... and you have a note that sticks out, and other notes that are muffled... The more you can vary the dimensions, the more it's like hitting a dense chord... all the notes speak. My cube is a good example of that. I sacrificed 80hz to get 40hz... 80hz sounds a little stuffy, 40hz comes through clear -- that's primarily how I got more 40hz out of the cube than hornresp says I should get. This last design doesn't have any 2 horn paths the same length, and because of the 'not quite' 90 angles, I accomplished something similar to scott's 12degree angle reflectors. 29 tall, 21 wide, 24 front to back, and the 27degree baffle angle making all the short paths of different lengths... it all makes this box sound good. I'm happy with it.
martinsson:
I must have access to the worst ply in the world here - I was getting enough flex with 17mm ply horn designed around a 12" driver to significantly distort the impedance plot above 80 Hz (and by extension the response above that area). I had to resort to bracing and doubling the thickness of the panel closest to the driver to address that, and I can still detect quite a bit of vibration on one of the box's external panels. And your design uses 1/2" ply for a larger box holding a 15" driver and you're not running into panel flex issues? I want some of that ply 🙂
plywood has a very different stiffness in one direction compared to the other direction. I seem to recall that the grain of the two outer layers runs parallel to the long dimension.
If a panel is flexing, could it be that the less stiff direction is being used, whereas cutting it from a ply in the other direction could much reduce the Xmax of the wood panel?
Would bonding a layer of carbon fibre reinforced plastic (CFRP) to both faces improve the panel's stiffness to such an extent that a thinner plywood (and a lighter/cheaper) speaker, results in good performance?
While auroco is not baltic birch -- it's 5 even thickness plys, and the best thing available to me short of baltic.
My rule of thumb is any panel over 12" needs to be braced, and in this design it is. A steel grill will brace the mouth, so all is covered.
Running my hand over the exterior panels while running sine waves at 28v is very encouraging. Yes there are small vibrations, but they are small and nothing I've not seen in any other pa cabinet. (I really don't care if my impedance peaks don't quite line up with hornresp, and that I'm losing a little efficiency due to some flex -- this is pa, not studio.) In short, if I had additional ply avail to me for this design -- would I spend it on braces? There are a couple internal panels I think I'd feel better with a brace or two, but that's it.
Actually the loss of efficiency is more important to PA than studio use 🙂.
Seriously, a distorted impedance plot suggests that there could also be higher distortion around the affected frequencies (a vibrating box panel does not make a good linear transducer).
The plywood generally available locally is called "viola ply". It isn't void-free, and it's not very sturdy. There's another type called "marine ply" available at significantly higher cost - I might try that next. I also recently got access to some MDF - but I'm saving that for another project 🙂.
I've gotten the best results using 1/2" fiberglass bonded to 3/4" ply, but the resulting box ended up being very heavy for its size, and likely not very suitable for PA use...
That would be a better option, but they make you pay for the "marine" part. It will be void free though.There's another type called "marine ply" available at significantly higher cost - I might try that next.
Hi!
Well done jbell!!
What helps me to identify where the panel flexes is put some thicker construction dry sand over the inspected panel;
Now a sweep test tone...
Where the problem (flexing) is the sand will jump, dance...
Save the same sand, turn the box, put it over the next panel...
Regards,
Well done jbell!!
Regards,
is jbell's TH drawing at it's official level? - if so would like to send it to a friend - what woofers does it like best?
- Subwoofers
- Single sheet TH challenge
