Single Ended Tokin SIT THF-51S Common Drain Mu Follower Amplifier, 45W?
As a Mu Follower Follower this amplifier is not pure single ended. The mosfet in the constant current source part of the circuit contributes to the overall power output, in a push-pull sort of way. So the maximum power output at 4 Ohm may be considerably more than half of the maximum power output at 8 Ohm. This is particularly a plus if your speakers' impedance is much lower than 8 Ohm. Since this amplifier has higher output power it may be used with speakers of lesser sensitivity, and many of these speakers' impedance is lower than 8 Ohm. Therefore the 4 Ohm power output of the amplifier is useful information.
When I first built this amplifier I ran it at 2.5A. At 8 Ohm loading the maximum power output was somewhere between 45 and 50W, depending on the maximum amount of distortion that is tolerated.
I tested the amplifier with a 4 Ohm load and clipping started at about 28W. I also simulated the 4 Ohm load condition on LTSpice and the result was quite close to the real thing. So the LTSpice model of this amplifier seemed to give fairly accurate results.
I have been running my amp at 3.0A lately for slightly higher 8 Ohm power output of 50W and lower distortion. I will post the 3.0A 4 Ohm results next.
Here are the results for 2.5A:
LTSpice Simulation:
THF-51S MuFF 62VDC 2.5A Right Channel DIY FE 4R LTSpice Sim Clipping at 28W.jpg
Actual measurements of right Channel:
Onset of clipping at 28W @ 4 Ohm:
Clipping at 30W @ 4Ohm:
Reactions: birdbox
Here are the rest of the 2.5A 4 Ohm distortion measurements:
And here is the 62VDC 3.0A 4 Ohm clipping LTSpice simulation:
And here are the 4 Ohm measurements of the amplifier at clipping:
Increasing the quiescent current to 3.0A resulted in a big increase in 4 Ohm performance.
The LTSpice simulation results were fairly close to the actual measurements.
Here are the rest of the 3.0A 4 Ohm distortion measurements:
Reactions: JeyDee
I also looked at the 75VDC 3.0A version. The 8 Ohm maximum power was 70W. The 4 Ohm output started clipping at about 54W with 0.69% THD. At 2% THD power output was 60W @ 4 Ohm.
Clipping at 54W @ 4 Ohm:
THF-51S MuFF MuFF 75VDC 3.0A DIY FE Left Channel 4R 54W Clipping Waveform.jpg
Clipping at 60W @ 4 Ohm:
The rest of the 75VDC 3.0A 4 Ohm distortion measurements:
Hi Don,
I do not have a 75V - 90V version.
The PCBs that I did will work up to 80V, and that is limited by the size of the capacitors that will fit on the PCBs, although I do not recommend using an 80V power supply. I recommend keeping the power supply to 75V in order to not exceed the specified voltage of the capacitors.
I originally built the amps using a power supply that put out about 63V. I recently changed one channel to a 75V power supply and the circuit changes were shown here:https://www.diyaudio.com/community/...mu-follower-amplifier-45w.371187/post-7867907
The original PCB was used for this change. R4 was no longer required and was replaced with a wire jumper. R7 was changed from one 0.1R to two 0.1R in series. Alternatively R7 and R8 may be changed to 0.15R 5W each.
I do not intend to build a higher version for an even higher voltage power supply as 100V electrolytic capacitors are quite expensive. Furthermore higher voltage means also higher heat dissipation, probably pushing the THF-51S to its practical limit or over its practical limit.
Reactions: pfdavid
If you have enough heatsinking/cooling, 3A is doable. Right now I have one channel running at 75V and 3A and the other at 63V and 3A. The 75V amp is good for 70W at 8 Ohm and the 63V amp is good for 50W at 8 Ohm.
The heat dissipation is appreciated right now!
And by the way, because of the contribution of the mosfet in the mu follower circuit, the 4 Ohm power is not bad either.
At 63V and 3A, the power was 42W at 4 Ohm. THD was 0.96%.
At 75V and 3A, the power was 54W at 4r Ohm. THD was 0.69%.
When the amp is clipping, there will be lots of harmonics. If you increase the power supply voltage, the amp will be able to output more power before clipping. However, there is the additional heat dissipated by the SIT to be dealt with.
It may also be possible to adjust R2 and R13 to tune the push-pull action which may increase power output, although that will also change the distortion profile.
Will this work with another SIT too? Just adjustable bias? Or slight adaptation of the trimmer (answer = yes, trimmer is 200K ansd allows a crazy range) to get the Vgs -7V for the likes of 2SK180, or 2SK182? Have them . . .
I don't need the 3Amps/75V (my wife will see the power bill. . .). 40V @ 2Amp is a lot already, enough is enough, because remember, we normals listen only to the first one or five watts. Even on 4Ω.
I saw a layout (ZM??) i remember that has pre-drilled holes for the P-FET 'module', which is handsome.
Note that distortion plot is for 4 Ohm speaker load. The second harmonic is dominant for the full power range into 8 Ohm.
At 4 Ohm, the third harmonic becomes dominant at higher power output. At low power output the second harmonic is dominant.
Decrease the quiescent current will increase the second harmonic but it will also decrease the maximum power output.
Decrease the mosfet's contribution to the power output will increase the second harmonic into 4 Ohm. That will also decrease the maximum 4 Ohm power output.
