Simplistic NJFET RIAA
3D printing has its place. A shielded enclosure isn't suited to it. You would need a ferrous material, hard as heck so you could drill and tap it. The cost would be stupid high.
The goo for my custom insulators was $300 a litre 5 years ago, high loss in the printing process. It was repairing a bad design done in the 1970's, so no other options. 3D printing for me was the best option.
I don't like the screws on the outer enclosure. So that's why I thought to make a 3D print something like this below (it's just a draft file without any ventilation). It's very hard for me to make something like this in metal, and also outsourcing this will triple the cost. So I think I will go back to the modushop encloser for the safer side.🙂
Here’s my old raw. Looks just like I experimented with just taking the voltage down, I don’t remember, life came in between. I used dual single 18 in series because that’s what I had around apparently. So one dual secondaries 33 VAC 60 VA, to not take up so much space, is that a go? I might order for a future UFSP and some other stuff to.
Thanks. The ones I ordered from the same series before had a shield between primary and secondary, but I’ll recheck! This is Audio Grade. There is also Supreme Aduio Grade V2 with external metal housing but thats upping the price considerably. Nice to look at however 🙂. Ideally I’d have one raw PSU for both FSP and future UFSP.
Reactions: Salas
From their product description:
AUDIO grade transformers for use in amplifiers and other high-class audio devices.
Unlike commercial power line transformers, the AUDIO version is covered on the outside with a black Mylar tape which gives it an aesthetic appearance. The epoxy filled center with an opening for the M6 screw eliminates a need for an additional mounting bracket. The neoprene gum pad affixed to the bottom successfully eliminates transmission of vibrations.
The entire construction utilizes high-class, laboratory-tested parts. The core and the windings are impregnated, and the production process is being scrupulously controlled at every step.
Additional magnetic screening and the electric monitor of coated SYN-SHIELD copper tape between windings make the class AUDIO transformers one of the frontrunners in the area of safe use in the systems of electronic power supply.
We guarantee quiet performance and the highest electrical parameters.
If its for LOMC or MC or even HMC cart the input wire length for pF is irrelevant. Due to such carts have low inductance and they won't resonate. If its for MM you want to keep pF in check. Both for the TT incoming wires capacitance vs length as long as to a lesser extent for the internal run.
Is a short as possible length of the DC wire running between UBiB and phono board critical and would shielding be beneficial if the length of the cable needs to be say 15 cm?
