3 months later quite well, thanks. Now I can finish my RIAA: the pcb is on my desk, ready to be populated.You are the big one, how do you do? a lot of time without hear nothing from you?
Last month I had a chance to meet some Barca supporters in Greece (during the supercup) and had dinner toghter the day after 😉
Done, now I have to measure the voltage across LED strings?
I am glad to hear now you are well, please photos & schematic of your RIAA will be helpfull (you know star gnd & star power).
Barça supporters are good people, sure you enjoy the dinner🙂
4 LEDs 1.88V measure 8.33V😡 & I need 7-7.3V
The matching Idss for 60dBs I have is for 8-9mA Idss, don't need the jfet 8-9mA Idss instead 6-7mA?
Salas, which is the min - max V of the led string in the RIAA 60 dB front end? Are 3 x 1.9-2 V leds enough?
I might have the same problem...
For this one around 7V is better bias. Use 3 leds if they are strong and one non Schottky diode. A normal one.
... such as 1N4148 or 1N400x ?For this one around 7V is better bias. Use 3 leds if they are strong and one non Schottky diode. A normal one.
Thank you!
Use 3 and a diode then. The Leds Jfet has nothing to do with the rest of signal gain fets.
Can I use 1N4007?
Thank you!
Both OK. Breadboard one along 3 LEDs and see what it gives. Then match another hybrid. Its as low noise as a LED but good for that 0.6-0.7V you may miss if with strong LEDs that they overshoot if 4.
*1N4007 looks OK too. Try it out.
Salas,
have you tried out the ZTX450 instead of the BC550, is this an opportunity?
I understand you perfectly.
Only was curiosity I'm not enough knowledge to make a simple tonearm so for me is impossible to do a super-tonearm to fight vs the best design ever made.
Merlin,
there are many "simple" tonearms out there. For a SPU or DL103 I'd recommend the arm from Thomas Schick. A winner for it's price.
With 15V & 0.02A measure 6.3V it's ok? wich measured voltage I need to look for 7-7.3V?
Merlin,
Looks nice but at this moment I prefer follows with mine Linn Ekos.🙂
0.02A (20mA) seems quite a bit too high.With 15V & 0.02A measure 6.3V it's ok? wich measured voltage I need to look for 7-7.3V?
Try 10mA and 5mA and measure the string voltage at these lower currents.
OR
use your chosen jFET+R17 as the CCS and test the string voltage using the actual jFET.
The R17 value of 180r will reduce the k170 current to much below it's Idss.
Using post4728 for circuit details & values.
It won't be wise to run that ccs fet at full idss because it sees a high potential across and it will dissipate much. He could use a dropping resistor before it if deleting the idss resistor. Say 3k3 1W between B+ and fet. Leds are at their most quiet from 2-7mA normally.
Salas,
I did not say that anyone should run that jFET at Idss.
I said
There is a big difference between to and too in english. Is that the problem you are having?
I said
That is the current that should be used to check the voltage of the diode string. Not at the 20mA quoted earlier.The R17 value of 180r will reduce the k170 current to much below it's Idss.
Salas,
Try low Rbb Toshiba etc.
- Analogue Source
- Simplistic NJFET RIAA
