Simplistic mosFET HV Shunt Regs
Vgs Q3/R8 creates Q4 Q5 Ic (bias current). Typically 4V/1.8k=2.2mA. Little on its own but dissipation W is Ic * HVout. About half of it on each TO-126 transistor. To keep same Ic and dissipation with a 6V Vgs Mosfet R8 is 2.7k.
Thanks Salas!
So the change is to increase the drop across R8 to get the Vgs up to 6V that the new mosfet needs. At the same time keeping the same 2.2ma through q4/5 so 6/0.0022=2.7k. Dissipation on r8 goes from 9 to 12 mW.
10mV 0.2ms 10x probe
Measured taken between SSHV2 and cascode CCS probe + and probe - to GND, right pic without probe - to GND
On first look the system seems oscillating. It could also be about interference.
It can be doing it with the particular CCS load but if measuring SSHV2 alone with just dummy load, not doing it.
In any case repeat with short gnd spring accessory to make sure its not interference on the probe's gnd crock wire.
Definitely there is something no good using togheter SSHV2 and cascode CCS or Ale's Moglia aka Bartola hybrid mu-follower (gyrator) so active load reacts very bad with SSHV2 so if I want to use SSHV2 only with anode resistor load, I guess no problem SSHV2 with anode choke load or line output transformer.
Did you use the new Mosfet?
Did something blowup again?
Are you talking about a siberian 4 -type setup?
Maybe it's a type of hall-of-mirror between the the two CCS in series. Don't know if it's the right way to call an oscillaition like this.
For all intents an purposes the SSHV2 has already all the PSSR you will ever want.
