Simplistic mosFET HV Shunt Regs
The LED can be RED, or ORANGE, or GREEN, or YELLOW.
Each colour comes within a range of voltage and that voltage range varies markedly with production method and manufacturer.
Expect 1.55V to 2.1V as the range within which all those "normal leaded end" LEDs will fall.
You have to measure the as built circuit to confirm what currents are passing individual components. Then adjust component values if necessary.
Today I decided to finish my second SSHV2 for the pre I am building.
Both shunts on the test bed working nicely, and voltage is very stable.
Just be careful if you use long cables without any decoupling. I managed to get it into oscillation with very long test cables. A cap near the input and everything is fine. Nothing burned this time, but future builders do not take the risk.
Just curiosity, wich pre are you building?
Looks good George. Did you decouple the long input leads giving you trouble right at the input connector? And with what C value? 0.1uF?
P.S. Or is it the big one at the crock clips decoupling further down the road?
