Simple Symetrical Amplifier
SSA Low Impedance HP
Thanks LC,
awaiting the values necessary to hear an SSA at power .....:flame:🙂
Here it is, SSA suitable to drive yours low Z speakers. :wiz:
I suggest you to built two monoblocks solid as a rock and please provide good and fast thermal dissipation. 😉
The worst output BJT SOA case is at 25 V output voltage on 1 ohm impedance, resulting in 625 W power dissipation on 6 outputs (104 W per one BJT) which is managable with a good heatsinking. 😎
Regards Andrej
hey Lazy Cat, thanks for the help, its a personal foible of mine but id rather bend the legs out a bit rather than rearrange the board and swash all the tracks close together. i work it as about 2mm on each trans to get the faces touching.
as long as the face touch i don't see it as a problem, and i find the extra space around the tracks helps with me etching and drilling my own boards.
thanks again, steve.
Regards Andrej
Thank you LC........... no i can go off and play ....:car:...🙂...:drink:
trying to play music into 1ohm speakers seems worse than really silly !
Your Ignorance is unbecoming Andrew , Grow up .....:nownow:
"The test of the machine is the satisfaction it gives you. 🙂There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed."
Robert M Pirsig.
Wow, look at them output transistors, 6 per side !
I name this circuit the "E-Type" - with the V12 😀
LOL...😀 I like it SSA-V12 .....................:car:....🙂
Regards Andrej
Hello LC,
Can the outputs be substituted with MJW3281A/MJW1302A..
Regards Andrej
That s a lot of transistors according to this poster :
Nooooo, too many transistors according to thread theme. 😱
Besides this is not somewhat Joachim meant. Check my last sch, DRAIN output ...
SSA Balanced Low Impedance HP
Lazy Cat,
Thank You for the SSA V-12. :worship:
A masterpiece of its own . :wiz:
Please, can You add the dedicated Balanced Input stage to this particular design that will make this SSA-V12 best of IT. . ... :flame: :cheers:
I just couldn't resist to this request. 😀
The Beautiest V-12 Masterpiece
Dear Mr. Andrej
:worship: Thank You very much for the most beautiful SSA-V12 version. :worship:
You make me the beautiest day since long time awaiting for something to drive my speakers civilized - and You make it. :cheers:
I know, this is the most Generous Scorpio's gift, You give to the whole worldwide sound-lovers & audio community. Thank You ... :worship:
:worship: Long Live & let God :hbeat: bless You . . :worship:
Andreas
