SEWA - Seven Watt Amplifier
Hi Mad!
I meant this resistor:
"...You can adjust the
gain of the circuit arbitrarily by adjusting the value of R15 without
affecting the quiescent DC values of the circuit. As you decrease the
value of R15 to 0 ohms, the gain will approach 50 (34 dB). As you
increase the value of R15, the gain decreases, with 430 ohms giving 10 dB of gain...."
Now I have 124 Ohm like in the schematic.
I encourage you to try the BZLS
I am in the middle of the listening test with my BOSOZ too.😀
Greets:
Tyimo
Professional SEWA PCBs?
Jason ( jleaman) wants to have professionaly made SEWAr1 PCBs. I have made a pcb layout for prototype production, and I will run this if there is some interest. I've managed to make a nice single sided board, plated through holes, soldermask and silkscreen. Board Size is only 25x80mm. The cost will be 10$ per board. I will only make 8 boards on this proto-run, and then build/test it. Jason wants a pair, so for now there will be only 2 pairs available. If there is continued interest I will have some more boards made.
Post here or email me directly if you are interested.
Re: Professional SEWA PCBs?
Good job. I can see this project going under toe. SOME ( i say openly ) may want a psb for a Psu. I'll design that if you are ok with that. We can talk more.
Jase
Update
As it turns out, my PCB supplier will not deliver single sided boards with plated through holes, only double sided. I am in the process of redesigning the layout for a 2-layer board, gold plated, green soldermask on both sides and white silkscreen on top. I want to take advantage of this, and use some SMD parts (0805 and SOT-23). This will be a better performing board, a little smaller 25x53mm, but some are reluctant to do SMD soldering. I can now get the price down to 7USD per board. How do you feel about this?
From this proto-batch there will be 5 pcb pairs available. jleaman and Jack C. have expressed interest, and if they are up to some easy SMD soldering, I have 3 pairs available.
BOSOZ FUSE problem
Hi Mad!
Sorry for the off topic question, but maybe you could help me.
After 3 years operating my BOSOZ's fuse (F-1A) blowed 3 times in a couple of days.
The amp always worked very well. I checked everything in the amp and all the reference voltages are O.K. In the test I operated with F-2A fuse.
What do you think, is it normal or paranormal??😉 What could be wrong?
BTW, is it O.K. ,if I use the + and the ground output for the unbalanced operation with the SEWA V1?
Greets:
Tyimo
