Looking for Mads
Hey, Mads!!!!
Wher are You?!?
Are you still on hollyday? 😀
We are missing you a lot!😉
What about the BOSEWA?!?
Greets:
Tyimo
Hey, Mads!!!!
Wher are You?!?
Greets:
Tyimo
Hello Tyimo, I'm back from my vacation now. I've had pcb's made for BOSEWA/Aleph L 1.2 , but I haven't had time to actually build/test it.
As I am in the process of moving to another apartment/giving it a serious makeover I have very little time left for anything else. Looks like it's going to be like this for at least a couple of months 🙁
Hi Mads!
I know this situation from end of the last year and I wish you the bests!😀
Only one theoretical question: how could I calculate the output power for the choke loaded SEWA (or better to say OTA)??
I would like to use:
120mH 0.5R EI core Choke
+24V supply
8R load
I only know: 24V/8R=3A bias
and on 20Hz the choke has 15ohm resistance.
Greets:
Tyimo
+24V supply
8R load
Greets:
Tyimo
Sewa and z=15 Ohm?
I would like to build Sewa amp but I am wandering if it is good for Lowthers with Z=15 Ohms? What can I expect?
Thanks.
Thanks.
6C45-PE
This tube will run at 24V and drive a low impeadence.
http://digilander.libero.it/paeng/6c45_pe_low_power.htm
This may be the tube for SEWA, just received all the parts to start my SEWA and have a few 6C45 tubes in my parts bin, this may be my next project
after my bathroom remodling is complete😉
Re: Sewa and z=15 Ohm?
In that case you should use 24VAC transformer for 30VDC+ rails. You can also lower the bias to 1,5A 😉
ticovski said:Hi,
Thanks.
Re: Re: Sewa and z=15 Ohm?
I have transformers with 30VAC secondaries, from zen v.1. This would give me 34V after Pi filter. Is that too much?
What I shuld change to get 1.5A bias? Can you suggest exact values? I hope I don't ask too much 🙂
Thanks!
Thanks!
Re: Re: Re: Sewa and z=15 Ohm?
34V is nice. Bias is defined by the 0,6VBE from CCS transistor divided by the CCS Source resistor(s) 😉
Thanks!
Re: Re: Re: Re: Sewa and z=15 Ohm?
CCS Source resistor -> R12 to R16?
CCS transistor -> Q3?
What is VBE?
What is VBE?
Just to be sure and not to burn something 😎
For Bias of 1,5 A - R12 to R14 should be 0,4 Ohm. So, to achieve that I need 2 resistors of 1 Ohm in series parallel with two resistors of 1 Ohm, also parallel to those in series? Right? If yes I am ready for shopping 😀
Regardless of how you do it you will want a resistor with 0,4 ohm and a 2-3W rating. How about 5*2ohm 0,6W in paralell?
Mad_K said:Regardless of how you do it you will want a resistor with 0,4 ohm and a 2-3W rating. How about 5*2ohm 0,6W in paralell?
even better like that. now I am going to shopping for parts and I am back when I am done.
Thank you!
BTW, how many wattts one can expect from 34V, 1,5 A and 15 Ohm loudspeaker?
Is it possible to use a trimpot to set the current trough the amp,I mean if I use rather small heatsinks.Where could I use the pot?🙄
I have thought of using SEWA to drive a RIBBON in a triamped 3-way system
The loss of gain in Sewa is maybe compensated by higher efficiency of the ribbon
Any comments on that ?
Hard to explain - but how much higher efficiency is needed from a midrange driven with SEWA - to align with a woofer driven with amp with normal gain ?
"Normal" gain is something like 26dB. Midranges does not normally have higher sensitivity than woofer. Anyways, it would not be in the 20dB range. Sorry 🙁
Ryssen said:Is it possible to use a trimpot to set the current trough the amp,I mean if I use rather small heatsinks.Where could I use the pot?🙄
Bias is set by the value of R12-16. If you can find a 1 ohm 3W multiturn pot, you can insert it there and have adjustable bias 😉 Another option would be to use a switch to short out some resistors.
- SEWA - Seven Watt Amplifier
