Thanks DannerD3H
Ben thinking about Hypex' 3 way amp, but had no idea how HFD worked.
I was wondering that if you just wanted to do a 3 way crossover, would it be enough to drop some low - and high pass filters?
...and then let DIRAC do the flatline response?
Best Regards
Brian
Best Regards
Brian
Hi, searching the net for answers, trying to get my UMC22 & ECM8000 working with REW & then HFD.
Does all the sound have to run through the soundcard, mine doesn't have XLR out, only L&R 1/4" jack connections, guessing these need to run into the Fusion?
Guessing I need to buy some cables, so 1/4" to XLR or phono?
I can see an import button, but this seems to load a DAT file. Just tried to save a file from REW and its saving as MDAT and not visible from HFD.
You can edit REW measurements as txt and save as DAT then you can load into HFD. I tried and it worked for me. If I remember correctly, something in the beginning of the text must be deleted from the REW measurement.
Are there any guides for how you measure direct in HFD?
RTFM!
So yes, I scanned through the whole manual, the first bit of "import speaker measurements" through me of the scent at first.
But near the end it does give instructions under Recording of how to record from within HFD.
I can't seem to get my behringher mic and pre-amp to work with REW or Fuzzmeasure, despite showing it seeing a signal on my mac. Maybe I can try with HFD later.
- Class D
- Setting up a Fusion Amp 3-way Step-by-Step
