This is the object of your desire, you've waited a year to get. 😛Hi Roberto..
i'm in for a stereo casing...so the list.
1) Giannettino 1 stereo case
you're in love with the style of design perhaps? ...you did not ask the price hahaha!
Ehm .. This is the type of customer that I like. 😀
Hi,Thanks for your interest.Interesting! I'll wait for the custom case.
As far I understood (sorry, it's Monday and I'm totally numb, maybe you've already said it), it's a complete kit PSU+AMP stereo (or dual mono?) + case... ready for my noobish hands?![]()
yes, we have the MDA-400 dual mono (module, complete with integrated special smps for audio) input board, cable, all connectors.
and, at short, the case for dual mono integrated (2 x MDA-400 in one case, or the single mono case (need two for stereo).
Please, see some pics on the thread.
I was just looking at the pics... really really nice.
Can you PM how much is the lot?* I mean 2xMDA-400 in single case.
Dunno if I can be usefull as a tester. 😱
Thanks a lot!
*lol, just read you post before... sorry! 😛
Ahah! I'm happy after long time you show your MDA-400 ..The return of the MDA-400![]()
Need the enclosure then..
How you listen this toys? are happy with sound?
Good question...not have at the moment.Soo.. Whats the price for the enclosure?! 😉
We wait some components for the two version of case,then I can offer single or stereo enclosure.
Also, at short I present this kit with new MDA-400 (just populate with nichicon audio grade caps) and +58V instead 52V.
I hope some diy chose well,see well...listen well 🙂
I will keep an close eye with this thread then 🙂
Good Morning,
@Darb You have received products??
Hope today I can show photos of new MDA-400-Kit.
regards
regards
UPS is very fast, but I live in the mountains and UPS does not come so far ...
My package is in the Post office and I'll get late in the day ...
thank you!
thank you!
What type of led do I use for indicating clip fault on/off?
Hi ,
You can connect direct on CN (input pcb) without res.
Right "CLIP" is better orange High-Light. (others as generic LED)
For on/off, you can use simple 1-pole permanent switch, connected on CN5(2PIN) and add a Led in parallel,via resistor 470R-1K depeand light.(see polarity on CN5)
Blink at start and immediately turns off. Simple scheme is on thread.
Hello Amateurs,
I'm ready to offer the first High-End in Kit.
Two version:
The Mda-400-Kit1:
Complete of all in photo (need only a empity case 1U)
The MDA-400-Kit2:
Includes stereo case, 4 color top/bottom cover available (of 6 final)
Power Output 2x340w (4R) 2x520w (2R) SIN 1Khz
Both kits, they use anodized aluminum frame, which allows easy mounting in any case 1U, as well as offering a product tested in terms of EMI / RFI shielding and thermal performance. (the maximum excursion as Delta, is 25 ° in any condition of use.
The kit also,includes 4x special wire (for speaker connection), made of pure copper 2mm diameter, solid (very flexible), covered with a polyester sheath.
This ultra compact dual mono, has a current into the load of 32amp peak per channel, perfectly repeatable as audio transients.
....A good reason to listen good music or... impress your friends 🙂
P.S. I want to take this opportunity in this forum, so I need a list this week, just to know if I can keep confidential the 20 kit that I have.
Needless to say, in a week, I received from 'Italy 60 order (1 week), do yourself a little deal.
Continue...
Two version:
The Mda-400-Kit1:
The MDA-400-Kit2:
Continue...
I received my package 🙂 ... Impressed by the packaging, very nice...
The quality of the whole is more than excellent, I would quickly connect all this to apreciate this quality amp but ...
But i'm missing some connectors ...
There were only 4 parts thereof, (and I've broken one ...)
And no molex 4 pin...
The sink hole is too small for the screws;
Ok these are just details ...
I have to buy some components for another project. I become crazy wenn i try to find everything I'm looking for ...
Roberto can you give me references/name (or a link) of connectors for the Colour Coded Ribbon Cables because I can not find this product ...
Is there a need for a heatsink for sda400 module?
good day,
Dear Darb, is a cruel fate, nice products with some stupid mistakes, I am mortified by these happened.
For the heatsink, this is a defect in the mechanical processing.
Ah .. no doubt about that, right now I have a person only for the control of all the parts, one by one before the closing of the package.
To see the connector IDC10PIN it.farnell.com/amphenol/t812110a100ceu/socket-idc-2-54mm-a-10-vie/dp/2215232.
For the Heatsink, you have the possibility to increase the hole at 7mm diameter x 6 mm depth?
The SDA-400 does not require a Heatsink, if you can find a simple "L", it can make better fitting.
What kind of speakers do you have? The SDA + DPS-500/52V, has considerable fast high-current on load....you can imagine, only when you listen to 🙂
P.S.
If you do not have urgency (as one wek), I can ship small packages, via Post-IT.
Obviously replace the Heatsink also.
Your country is strangely expensive via UPS, I paid 60 €
P.S.
Thank you for the information Roberto,
I have found the amphenol connector one minute before you reply me... @ farnell...
But i can't find the "molex" female 4 pin that goes on the sda400... I not understand, it's a common connector...
Did you have a link on farnell web site?
For the heatsink it's not a problem, a friend can help me for making this hole a little bit bigger
Don't worry for this very little mistakes...
My speaker are DIY and i am going to make a system with active multi amplification. Your sda400 will be used for bass, for this I need a amp with good damping factor and here I think your system will be perfect. In the meantime I will use your amplifier only... when it will be ready ...
Is a normal female connector, 2.54 step,in line, made by many manufacturers.
We buy directly, so I do not know at the distributors good for DIY.
I find this at Mouser. seem that molex changed the shape.. 😕
The dimensions can help to choose a enclosure different. in this forum and on ebay, there are some nice case compact, cost around U.S. $ 30-40.
Thanks to the frame in AL, mounts easily with 4 screws.
If Your case have 50mm internal height, PBTU-3 can assembly in vertical also,this reduce depth -25mm
Hello,
I'm in for a kit 2. I'd like to know the price though 😀
Hello Amateurs,
Two version:
The Mda-400-Kit1:
The MDA-400-Kit2:
Continue...
- Vendor's Bazaar
- SDA-400 Professional multi-way
