• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
SDA-400 Professional multi-way
INFO:
Given the success that has seen the MDA-400 dual mono config.
I decided today to order 40pcs from our services. will be ready in 25-30 days.
Today we have only one kit as MDA-400 Dual-Mono version at + / -58V instead of 52V.
please, not bumbard me via pm or email.
likely also, custom case will be ready in the meantime.
regards
Count me in ! 🙂
@camelator : I live near Paris. Surely we'll be able to plan something when I'll have the MDA ! 😉
Hi Fabrice,
thanks for shared, eheh I have no doubt about this.
You must see the new Dual Mono I ordered, with which types of components arrive,
I am very happy when others are.
You put a sheet of insulating material under the regulators? you are crazy if you placed sda, without 🙂
Just my curiosity,not see caps on the PBTU board,you have changed with smd at bottom?
How much does Subbu dac?
I also have curiosity of listening impressions from Darb, becouse has powered the SDA's with DPS-500/DA ... @ 56V
Hello ! how was the week end ? productive!
well after I tested teh Subbu DAC with the SDA, I decided to start some testing with VSSA 🙂
problem is that I m struggling on finding the right balance between Bias current in the VAS and DC offset, but ok, nothing to do with the DPS400 🙂
so stay tuned
Roberto, FYI, I ve soldered the murata caps directly on the pin of the Elna, on the solder side 🙂 and the cost of subbu dac was around 70€ (pcb+components+psu) but it is a GB which is now ended.
Hi fabrice,the DPS-400 seem very small in photo..uh! is very large your Heatsink?
I not have listen impression from Others DPS->VSSA, so...:smash: I'm very curious..🙂
You have dedicate two DPS-400,one for each Amp..I'm wrong? or you have 4CH?
you are right, on this heatsink (comming from one channel of a vintage accuphase 303X) which is temporary, the heatsink comes to 41°C without load/signal.
so yes it seems the vssa gets hot 🙂
I hope to do som listening tomorow morning. This took a lot of time to prepare this equipement, and to calibrate it ...
Yes Roberto you are right I have 4 DPS and then I m planing to have 2 DPS for each channel (Left / Right). one DPS is for the 2 woofers (8') and the second DPS is for the Compression and the tweeter. This should be ok 😀.
But for the time being, I m just "testing" all of that in basic stereo mode with a single DPS 🙄. That is not optimal, but still it delivers a stuning result.
stay tuned
Hello Folks;
this is a nice shining day here on the east side of the atlantics 🙂
this is the DPS+VSSA "in situ" this morning
The first very good news , is that I cannot here any sort of noise in the tweet and comp. the DPS is clean and the PSSR of the VSSA is good. no need for additional coil or whatso ever fancy caps. no zzzz or chhh or fffff 😱
this is the first 30' of sound so this is not possible to give any judgment of any kind, either for the combi VSSA-DPS or for any comparaison between SDA and VSSA if anyone wanted that, sorry😀
let me say the music is just Good, so good. Well, very conventional I d say. soft, cool, nice, that doesnt rock as the first try with the DPS-SDA, something different, here. bass very good, but not as tight and powerfull as SDS (yet?).
Voice/mids less brillant, more soft but sill good details.
well. I must stop otherwise I would start judging things which cannot at this stage 🙂
for those questioning VSSA with DPS, I feel very very good with this combinaison (compared to my DIY trafo 1200VA classA/B 🙄 ). Still the 1000uF onboarded on the VSSA PCB might have a serious impact on sound.
for those questioning SDA vs classA/B, waouh, I m very very satisfied as you understood.
all of that needs more analysis...(and time!)
but my project of integrating both SDA and VSSA driven by DPS in a single solution is confirmed today.
good luck for your integration and enjoy the sound
INFO:
regards
Interesting! I'll wait for the custom case.
As far I understood (sorry, it's Monday and I'm totally numb, maybe you've already said it), it's a complete kit PSU+AMP stereo (or dual mono?) + case... ready for my noobish hands? :innocent:
Hi Guys,
Good News.
MDA-400 arrive from our services (all smd parts assembled).
Some parts of the custom design case,as cover,rear panel arrived. (both version,Dual Mono Integrated as showed in photo,and for Dual Mono single case (168x60x240)mm.
This in photo, is Blue Cobalt opaque. available 6 colors pastel opaque.
Well, tomorrow arrive first qty of Nichicon audio grade caps (full set),then start assemble and final test.
Availability for this Kit = 40pz.
MDA-400 Integrated Dual Mono complete Kit.
Professional high quality, it's a delicius amp with Modern high style case, goes well with stylized décor of your home,instead of old iron case I think.
Well, 1 year for realizze this case, as some already know. but I'm tubborn. 😛
You can see aspect of rear panel complete, in some photos in thread.
Then, this series MDA-400 at 58V with full Nichicon audio grade- deliver quiet 2x520w rms at 2R.
Behavior is typical of large Class AB, in warm sound and high current on the load (up to 22A repetible).
The case includes:
Top / bottom cover with logo in Perspex materials AudioPower
N-4 feet AL (made ​​on a lathe) + cathcu pins High grip
Rear panel complete with high-end components certified
N4 grills matt black (for the slots of the air flow)
Front panel, 10mm thick, rounded corners, with logo AudioPower.
N-2 side profiles AL & magnesium surface.
Reservation needed for this kit. The next amount we can get at May June. Considered amateurs waiting, mostly from Italy.
Also, I can not guarantee that the bid price, can be repeated.
Designed and made in Italy
The complete Kit,not require iron solder.
If interested, please create a list, I think we need 10 days.
Hello Fabrizio, sorry if I did not answer, but they are pretty darn busy.
Ah .. you're the perfect man for testing hard (long wires, without a metal base for the heart).
But this is good to test instability, and induced noise.
As you know, full-range, it is obvious that a smps DPS-400, for each amp, it is very much better. 😉
well, it should come out, even some tests from Pinnocchio , Also interesting because made at 120Vac 60Hz.
Single Mono-Block case version.
Also, we present the new professional Guitar Amp 100w 8R. 20Hz to 22Khz, 0.03% THD @ 100w.
Compared in Studio Vs. the best in the world Guitar Amps.🙂
Wait for A-600 complete Guitar Bass, powered by DPA-600/F.
regards
