• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
SDA-400 Professional multi-way
Interesting! I'll wait for the custom case.
As far I understood (sorry, it's Monday and I'm totally numb, maybe you've already said it), it's a complete kit PSU+AMP stereo (or dual mono?) + case... ready for my noobish hands? :innocent:
Hi,Thanks for your interest.
yes, we have the MDA-400 dual mono (module, complete with integrated special smps for audio) input board, cable, all connectors.
and, at short, the case for dual mono integrated (2 x MDA-400 in one case, or the single mono case (need two for stereo).
Please, see some pics on the thread.
I was just looking at the pics... really really nice.
Can you PM how much is the lot?* I mean 2xMDA-400 in single case.
Dunno if I can be usefull as a tester. 😱
Thanks a lot!
*lol, just read you post before... sorry! 😛
The return of the MDA-400 :cheers:
Soo.. Whats the price for the enclosure?! 😉
Good question...not have at the moment.
We wait some components for the two version of case,then I can offer single or stereo enclosure.
Also, at short I present this kit with new MDA-400 (just populate with nichicon audio grade caps) and +58V instead 52V.
I hope some diy chose well,see well...listen well 🙂
I will keep an close eye with this thread then 🙂
What type of led do I use for indicating clip fault on/off?
Hi ,
You can connect direct on CN (input pcb) without res.
Right "CLIP" is better orange High-Light. (others as generic LED)
For on/off, you can use simple 1-pole permanent switch, connected on CN5(2PIN) and add a Led in parallel,via resistor 470R-1K depeand light.(see polarity on CN5)
Blink at start and immediately turns off. Simple scheme is on thread.
Hello Amateurs,
I'm ready to offer the first High-End in Kit.
Two version:
The Mda-400-Kit1:
Complete of all in photo (need only a empity case 1U)
The MDA-400-Kit2:
Includes stereo case, 4 color top/bottom cover available (of 6 final)
Power Output 2x340w (4R) 2x520w (2R) SIN 1Khz
Both kits, they use anodized aluminum frame, which allows easy mounting in any case 1U, as well as offering a product tested in terms of EMI / RFI shielding and thermal performance. (the maximum excursion as Delta, is 25 ° in any condition of use.
The kit also,includes 4x special wire (for speaker connection), made ​​of pure copper 2mm diameter, solid (very flexible), covered with a polyester sheath.
This ultra compact dual mono, has a current into the load of 32amp peak per channel, perfectly repeatable as audio transients.
....A good reason to listen good music or... impress your friends 🙂
P.S. I want to take this opportunity in this forum, so I need a list this week, just to know if I can keep confidential the 20 kit that I have.
Needless to say, in a week, I received from 'Italy 60 order (1 week), do yourself a little deal.
Continue...
I received my package 🙂 ... Impressed by the packaging, very nice...
The quality of the whole is more than excellent, I would quickly connect all this to apreciate this quality amp but ...
But i'm missing some connectors ...
There were only 4 parts thereof, (and I've broken one ...)
And no molex 4 pin...
The sink hole is too small for the screws;
Ok these are just details ...
I have to buy some components for another project. I become crazy wenn i try to find everything I'm looking for ...
Roberto can you give me references/name (or a link) of connectors for the Colour Coded Ribbon Cables because I can not find this product ...
Is there a need for a heatsink for sda400 module?
good day,
Dear Darb, is a cruel fate, nice products with some stupid mistakes, I am mortified by these happened.
For the heatsink, this is a defect in the mechanical processing.
Ah .. no doubt about that, right now I have a person only for the control of all the parts, one by one before the closing of the package.
To see the connector IDC10PIN it.farnell.com/amphenol/t812110a100ceu/socket-idc-2-54mm-a-10-vie/dp/2215232.
For the Heatsink, you have the possibility to increase the hole at 7mm diameter x 6 mm depth?
The SDA-400 does not require a Heatsink, if you can find a simple "L", it can make better fitting.
What kind of speakers do you have? The SDA + DPS-500/52V, has considerable fast high-current on load....you can imagine, only when you listen to 🙂
P.S.
If you do not have urgency (as one wek), I can ship small packages, via Post-IT.
Obviously replace the Heatsink also.
Your country is strangely expensive via UPS, I paid 60 €
Thank you for the information Roberto,
I have found the amphenol connector one minute before you reply me... @ farnell...
But i can't find the "molex" female 4 pin that goes on the sda400... I not understand, it's a common connector...
Did you have a link on farnell web site?
For the heatsink it's not a problem, a friend can help me for making this hole a little bit bigger
Don't worry for this very little mistakes...
My speaker are DIY and i am going to make a system with active multi amplification. Your sda400 will be used for bass, for this I need a amp with good damping factor and here I think your system will be perfect. In the meantime I will use your amplifier only... when it will be ready ...
Is a normal female connector, 2.54 step,in line, made ​​by many manufacturers.
We buy directly, so I do not know at the distributors good for DIY.
I find this at Mouser. seem that molex changed the shape.. 😕
The dimensions can help to choose a enclosure different. in this forum and on ebay, there are some nice case compact, cost around U.S. $ 30-40.
Thanks to the frame in AL, mounts easily with 4 screws.
If Your case have 50mm internal height, PBTU-3 can assembly in vertical also,this reduce depth -25mm
Hello,
I'm in for a kit 2. I'd like to know the price though 😀
Hello Amateurs,
Two version:
The Mda-400-Kit1:
The MDA-400-Kit2:
Continue...
