• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
SB Acoustics Satori Monitor
Joachim, today i saw on AUDIO Magazine 06-2014 that you got an amazing test result
for your suesskind BEO speakers. Many congrats to you for that ! And i like the look
and colour of the BEO alot. I can imagine the KALASAN with a 10" sub, too.
Martin
Thanks, yes, the BEO did really well.
I am sorry that i do not have any information when the Satori kit will be released.
David that originally comisioned this design has left SB.
When you need drivers you can contact me via PM.
I also have the circuit diagrams of the kit and the DIY version of the cabinet.
The DIY version was with a wide baffle and the tweeter set back.
Hello! I have made it!
Thanks, Joachim!
Is there any way to make a "Sticky" with the cabinet plans and crossover variations and include Jeff's Link to the his kit and Goran's as well! After all this is ONE LONG THREAD!
I am also curious what the difference between the 6020 and the 6600 for example! Also, I was able to sample the 6620 which is very impressive, what about the R3004/6020 as possible variations to Goran's Kit?
I've done a not yet published version of the "Satori Two - Monitor" with the Beryllium (6640) tweeter. All of the above mentioned tweeters including the 6640 requires a different cross-over for the tweeter filter section compared to the original design with the stepped baffle and the D3004/602010 tweeter.
The version I've done with the 6640 tweeter uses a 6deg sloped baffle instead of the stepped one.
I don't like the "R" versions of the above tweeters even though they look cool. They have a more linear and extended on-axis frequency response at the cost of a worse off-axis response and a higher distortion profile than the "D" version.
/Göran
______
/Göran
______
Thanks for the input on the R versions...so I guess they only question I have left is, since the 6600 is a lot more money than the 6020...what's the difference...besides the price difference!?? (Your last name wouldn't be Gillinger would it? I know another Swede named Goran, I'm of Swedish decent myself.)
Sorry, I'm not Gillinger.
Main differences of the D3004/602010 compared to D3004/660000:
  • Smaller and differently shaped face plate, 62mm vs. 104mm
  • No AirCirc motor layout
  • About 2dB less sensitivity
  • Lower Fs, 425Hz vs. 470Hz
  • Slightly higher distortion profile
  • Decreasing frequency response from 15kHz vs. increasing frequency response from 15kHz (see pictures)
They both share the same dome, surround and voice-coil assembly.
Attached pictures:
D3004/660000 = Blue
D3004/602010 = Red
Note! The graphs are normalized to about the same SPL.
For measurement details see:
www.audioexcite.com ScanSpeak D3004/602010
www.audioexcite.com ScanSpeak D3004/660000
For the price the D3004/602010 is a great tweeter. For a small face plate tweeter it's a great choice and is almost if not equally good sonically as the D3004/660000.
/Göran
