SARA-2016
I think I have finished drawing the new PCB. some advice, recommendations
I am also working on a triamping project with 3 SARA 2016 amplifiers, it took some time until I found the same housings for amplifiers and active crossover and tone correcting preamplifier (what you see in the pictures are only empty housings where the modules will be mounted)
Reactions: greierasul
I gave up on the first project, for the first time I wanted to mount all 3 amplifiers in one sharp case,,,,
Friends I have successfully completed the second module of SARA2016. I am toying with the idea of making 4 monoblocks with these modules and fitting each with a 600W toroidal transformer and 88,000uF filtering. I'm thinking about plugging in a BI-AMP, ...I just don't know if such an investment to minimally improve the sound is worth it. What do you think about wiring a BI-AMP? 🤔
I did some tests on a 15 inch horn and driver, with this SARA 2016 amplifier, and of course on the station with lamps,,,,,,, the surprise from the SARA 2016 amplifier
surprise, as you can see everyone listens with class A amplifiers with horns, but the SARA 2016 amplifier of course has a high damping factor that many amplifiers do not have, and the music is controlled very well by this amplifier.
Reactions: inyashd
