Sansui Alpha AU-907i MOS Limited
About checking the voltage across the white resistors it's a bit difficult there are total of 16 resistors and 2 meters. I'm afraid put the mini hooks across the resistors in live. So I will need to shut down the amp 8 times for cold condition and 8 time for hot condition.
In analogus situations (eg. temperature testing a circuit in an environmental chamber), I tack-solder lengths of hookup wire to each test point of interest and bring the wires to "the outside world." Typically, I strip about 1/2 inch of insulation from each end and push the ends of each wire through small holes in a piece of corrugated cardboard. This keeps the all test points safely separated and easily selected for measurement. I pencil labels on the cardboard at each hole to ID each test point.
If the test wire presents problematic coupling to the circuit under test, I often tack a series resistor between TP and the connecting wire to help tame susceptibility. Heat shrink insulates the resistor-wire connection.
All this preparation is tedious, but guards against mishaps and is time saving in the long run.
Good luck.
I turn on the amp now and this amp drives me crazy. The amp cold and for at least 5 minutes the sound appears on the both channels and after a time it start to make the problem with right side and again after it becomes worm it's again OK. The resistors on problem side (the right side) are much cold then left side but the temp on the transistors are opposite right side hot left side 10°C less. Green right red left (for the resistors).
On right channel the temp of the 2 last resistors are higher than the rest. On the left side the temp is +/- the same on all of them. OK I will try tomorrow to check the voltages across the resistors. Maybe bad 2 power transistors on the right side that are not in the spec.
That's why I asked you to measure every resistor voltage 😉
And the two neighbouring resistors ?
2 corresponding transistors temperature ?
If those 2 resistors are hotter, it means more current, so you will measure higher voltage.
Something shorted / partly shorted / open.
When the problem appears and I rise the volume the right channel becomes alive and when turn lower the volume right channel still there for a while.
Do you have a scope? When the amp acts up, check top of pot element and wiper to determine if pot is culprit. If necessary, bring out test wires from various points in signal path so that you can probe when misbehavior occurs. Use divide and conquer search to localize the intermittent.
Good luck!
Reactions: AlphaAudio
1:30am quick guess:
The 2 Mosfets or 2 resistors which are direct neighbours of the hot resistors are open = bad. So no current flowing, Mosfet and resistor are cold.
Because, seen from board edges, 1 pair of parallel Mosfets on both sides of the pcb. If one Mosfet / resistor fails and is open, the parallel part must take double current to establish the idle bias and get hot.
Mosfet open or resistor open.
Or bad solder connection on resistors, unlikely...
Best check the 8 0.22ohm resistors of bad channel as next step.
Thanks for all the comments. Yes I have a scop. I will check today voltage across the the resistors. When I turn on the amp, when the amp is cold, at the beginning the right channel act like it should for the next 5 minutes. The behavior is like parabola.
