Salas SSLV1.3 UltraBiB shunt regulator
Look how I soldered J1. Center leg it's on the left side and the left leg is soldered on the center
There's no voltage drop between the input and output section. Thus no current across R1 either.
First wind the output voltage adjust trimmer all the way down.
Then measure if Q2 shows about 0.6V Vbe (DC between base & emitter).
