Salas SSLV1.3 UltraBiB shunt regulator
I've replaced both of BC560C. Q2 Vbe 166mV Q3 Vbe 3.45V
M1 voltage between leg 1-3 is 11.56V (same as output voltage) M2 voltage between leg 1-3 0.585mV. Rload checked 99.6Ohm
Sorry the measured value on M2 is 585mV not 0.585mV
M1 must be wrong type or broken
I've replaced M1, but the voltage between 1-3 is 11.56 after the replacement. Not changed.
The measured M2 voltage is correct or is it too low?
I've put a new M2. I resoldered every joint. (I never had soldering problem) I measured the voltage drop on the R7 and still 0.5-1mV... and the led illuminating very low light. I measured again J1-J3 all between 85 and 100Ohm. I really don't understand. I changed the potmeter, Q2, Q3 M1, M2...
One year ago I made my own version of UltraBiB to one sided pcb, for home production. It worked first time, but a bit noisy. (I think, because of the pcb arrangement) Therefore I bought an official pcb with minikit to be sure everything will be perfect. My DAC don't want the perfect PSU 🙂
Thanks again for the patient and the help for the troubleshooting.
I attached photos from it. Maybe it's help
