Salas SSLV1.3 UltraBiB shunt regulator
With power off and still soldered on board you can measure Ohm between drain and source pins on the JFETs. Should be decades or hundreds of Ohm but not shorted or kilo or open. A typical healthy PF5102 can show 70-100 Ω or thereabout.
Yes Nichicon ES (BP) are alright for this reg in those positions. Although the RDS looks good in the JFETs we should also see them producing enough voltage drop on their respective 270 Ohm source resistors. Meaning 1-2 mA bias or about. Solder joints must be good, resistor values must be good, JFET gates must be good.
