Salas DCG3 preamp (line & headphone)
reconfigure DCG3 Pre
Salas,
I will be posting pics of my build by this weekend. Went pretty well. Absolutely dead quiet even at full volume. Sounds pretty darn good for first effort. Listening test on weekend. 13 months of build. Not for the faint of heart to go that long and not hear anything. Started from ground zero. Or, more like Zero degrees Kelvin. Not sure what I was going to get when I turned everything on. Overall topology is Salas FSP, DCG3 and M2x with an SP10, EPA 100 arm and ATG33-2.
Speakers are currently Tannoy revolution XT 8F.
Reason for writing is the DCG3 pre with I-select really kicked me on the build. All on me - novice. I wanted to re do and go more like the phono pre and separate the Trafos. Got 2 pair of Flexy boards from T. I think I have the flexy figured out. Use a 6800uF cap that matches the UBiB. Run a shielded DC power cable to the pre and ground the shield to the pre box like on the phono. My real question is best way to hook up the DC power to the UBiB. I will be taking the Quasimodo stuff and the diodes off the UBiB as it will reside in other box. Do I keep the little 0R33 resistor in front of the Caps and how best to wire it. This is set up as dual mono. There are 2 +/- UBiB's
Thanks for all you do .
Don
Wow—our systems are really similar irrespective of rooms and speakers (and tonearms). You will have to get the Hana ML unfortunately ;-) Haha. But really, you should. You've completed a full refresh of one of the decks? I can't imagine the need for a separate PSU for DCG3—quiet is quiet in my book—but IDK. Ultra FSP? Uh oh. 😀 An incredible amount of work that will surely be worth the effort, leaving you with a solid feeling of gratitude daily and with every use. Congrats!
Don
Hi
External DC power cabling to UBiB needs no special measures since there is no AC field emanating from the DC connecting wires. You may follow the phono's umbilical practice as well. Skip the bridge diodes and the Quasimodo components of course. Keep the 0.33R (RF) in series to C1 if the DC wires are thick and relatively short. But if they are long enough and kind of thinner flexible, they do offer little resistance of their own to naturally substitute RF's role.
Quick question. The dcg3 plays very well. However a slight "hum" can be heard from the speakers when ear is close to elements.
It seems as I got some 50hz(mains), 150hz, 250hz, 350hz, 450hz etc. fundamentals on the outputs. They are pretty low in level but they are there.
Any suggestions what can cause this?
Will post pictures later.
Here is a screenshot.
50hz (of course) and peaks every 100hz and smaller at 100, 200, 300 etc
Someone pointed me in the direction of rectification noise? I am using hfa08tb60 diodes on the dcstb PSU board.
https://www.vishay.com/docs/96190/vs-hfa08tb60-m3.pdf
I even disconnected the muses volume control (the psu for it) and the result remain.
Its somewhat clean build and thinking of desoldering all the inputs and just measure PSU and dcg3 out. Just to rule out the inputs and i-select board.
Lifting the IEC inlet gnd actually made the 50 and 100hz a bit worse. 150,250,350 etc. were unaffected of this.
Noisy kids here now. Limited time doing fault analyzes. Using focusrite solo gen3 for measurements and notice some has had some issues there also.
Hava a picoscope 12bit at hand also.
Was not quite easy.
Had to gnd the +-15Vdc PSU for the muses volume. I think I got rid of the 100,200hz noise. However 50,150,250 etc. is still there. I am a bit lost here.
Have gone through this thread that looked similar
150 Hz / 250 Hz / 350 Hz noise in linear PSU
BTW: The +-15Vdc PSU are actually 2pc +15Vdc which I connected to commond ground to get +15 -0- -15 voltage.
Like this in a way
Based on TPS7A4700.
Is that a good way of doing it or could that be the reason not having positive and negative regulators...
Better lift circuit gnd from chassis and verify it's floating. I don't know how muses volume control works but is it as usual sensitive to pot's shaft grounding?
