Salas DCG3 preamp (line & headphone)
Hi, thanks for your advice on the line outputs. I hadn’t considered driving two separate circuits with the DCG3, but it is an intriguing thought. Perhaps I’ll try something like that later on.
Forgive the noob question, but so that I understand, the hp output would have 49.9 ohm in series (at Rzj) to have a similar signal level at the output? I believe at the moment I just have a jumper there.
Very neat and professionally done!
Thanks Dewdrop. There were several iterations of the layout, and if I did it again I think I would mount the DCG3 and i-select vertically to shorten the input signal wiring, much like Salas and his friend did on their balanced build, and I think other members have done this too. Smart.
There are a few things I’d like to clean up, but for now I believe I’ll just enjoy the music.
Cheers!
The HP output to the phones will continue to have the "zero" Ohm but the tap to the second line output will be geting the in-line resistor.
Yes, it gets away fine, has 100mA bias with a thick alu plate that augments at the chassis. No worries for HP max power output in moderate bias because on the bridged (so called BAL) headphones connector it will produce 4x the mW of SE.
I see, thanks! Still, mine biased at 112mA gets hot and I had to build the heatsink like this.
Howdy everybody, I've begun this adventure and I have the wonders... I'm combining this preamp that will run my two phono sources that require gain with an Aikida tube buffer that will have a pad for components that are already outputting too high a signal for a power amp, sooo, I'll need a slightly complex relay system to not only route the inputs to the correct boards, but also share a common volume pot. The relays I chose are 12V varietal and there are four of them. Can I run them all off of the 12V relay circuit on the amp board? Thanks for any time taken to consider this question and respond as well.
The 12V on the DCG3 board's output relay is good for that one only. The three LEDs for dropping the +Rail can't take more.
If you also got the I-selector board, it already has a 12V chip regulator and auxiliary DC output connector pads from that.
If not, a way is to tap raw DC from a reservoir capacitor on the DCSTB PSU to feed a 12V chip regulator for your purposes.
Your build is very nice. Differently interfaced to the sink. I will let you know MOSFET tabs temperatures when we will finish our version of build. Due to the many big peripheral things my friend wanted to include we have no floor space left and we can not do much more than the thick Alu plate interface bolted to the chassis scenario.
