Rockford Fosgate 1001bd Repair Help
Just need to know what I'm testing
10R is 10 ohms.
You will see no difference between 10 and 47 ohm. Typically, when someone goes from a lesser FET (that likely uses a 100 ohm gate resistor) to the 3205, they replace the 100 ohm gate resistors with 47 ohm resistors. The 100 ohm would cause overheating of the 3205s.
