Rockford Fosgate 1001bd Repair Help
The SMD resistors are ceramic. You cannot bend them. Thye solder flat to the board like the rest.
I would not expect to see only 2 that are different. Which 2 resistors are different (circuit board designations)?
Are all of the 3205s from the same batch (same date code)?
Are the two resistors with a different voltage the only 2 you replaced?
When only 2 read different, that looked suspicious. When 4 read one voltage and the other 4 read a similar but a very slightly different voltage, that's not generally a problem.
You can test it without the heatsink but you have to monitor the temperature of all heatsink mounted components very carefully. If it doesn't blow the fuse and produces clean audio, apply heatsink compound and clamp it down before you do any further testing.
yes, the the 3205 ps fets. nothing blew. it wasnt hooked up longer then 1-2 seconds. i just verified it powed up. I removed all the 10R gate resistors and am awaiting for the 47Ohm to arrive, ill install them and test the rail voltage again before B+ again, and post the result. Thanks
I thought you said to use the 47Ohm gate resistors with the 3205's? Q21=A06, Q19=A56, Q17=A56, Q20=A06, Just like the other amp i havent touched yet. I have 10 Ohm gate resistors i can install. As for the Output side nothing appeared damaged, how should i test that side?
