Revisiting some "old" ideas from 1970's - IPS, OPS
Back to the amplifier please.
I wonder if any improvement expected using a separate power supply for the vas stage.
To be honest, I don't expect any noticeable improvement.
I would add a 2-pole CCS to R24 || R95 - I already have it designed, based on LM317 regulator - see attached.
Yep - pretty much as expected )
Luckily, the speaker's impedance falls down to that low level (if it does at all) at the low frequencies (below some 200-300Hz).
A good example is Thiel cs5i - a sophisticated five-way, six–drive-unit, having two 4-ohm drivers in parallel in the sub section (below 50Hz). So, we see the 2-ohm load in the range, where low-impedance-load performance is the best. Nice :cool:
P.S. Thiel cs5 impedance curve is taken from Stereophile test measurements.
Bottom line is impedance, top (dashed) line is phase.
Serious stuff, demanding a "tank" amplifier ;)
EsiJulia on Asus Mobo
A little more clear results using an Asus motherboard.
VZ-X4 distortion at different frequencies
Using ARTA.
Using RMAA
