Restoration and Modification of Pioneer PL-71 turntable
Sure. I'll send a few over. They might not be as good as yours but I'll see how they turn out. It will probably be later tonight. Also, do you happen to have any kind of testing procedure for the various components and what the readings should be? Like what it the output voltage on the POTS, the switch itself, etc.
6L6: I didn't get to posting the photos last night. Here are the ones I took. Also, I did some testing on the voltages. Here is what I got:
Power Leads from the plug to the power board: 120V
With 33 speed selector pushed down: 120v across the 2 white wires at the switch and of course on the power board also.
The 33 speed Pots: DC current voltage of 36v (Not sure if AC voltage is correct for a Pots or not. So I took a DC voltage reading)
Power to the Strobe Light is 15.6v but is doesn't light up.
The 45 Pots: 0 V
