Replacement For Toshiba 2SK170/2SJ74
nope
you need complementary pair (matched , of course) in BL range - to keep dissipation on bay
you could use pair of V ones , after measuring their exact Ids , then deciding where (voltage wise) to cascode them .... exactly from same reasons
trivial in fact , but demands some play with any pcbs you have
..... still trivial - all you need is dremel , 0.7mm drill and some fine wire
V Grade max Idss is 20mA.
If you cascode at 9V Vds, dissipation is 180mW.
Those devices are rated at 400mW for 125°C junction temperature.
Which means at 180mW the junction temperature is about 70°C, which is OK.
Of course additional heat sinking will always help.
Patrick
B&D enterprises is selling Toshiba 2SJ74/2SK170 pairs which are NOT matched. I gambled $100 and bought 10 pairs. Here's the Idss range I got:
SJ74: 10.0,10.0,9.9,9.3,8.7,8.6,8.2,7.5,7.3,6.7
SK170 10.1,10.0,10.0,10.0,10.0,9.8,9.5,9.2,9.0,8.9
Hey Kevin,
The jfet values look fine. However, this is both good and bad news.
The good news is you have at least enough for 2 amps.
The bad news is you may find yourself going to "Amplifier Anonymous" meetings
in the future. 🙂
But until then, do consider the Aleph-J.
Dennis
