I just saw that BDent has Toshiba 2SK170BL's in stock @ $2.69 each for 10 units.
Do they look genuine? I've bought from them several years ago, but wanted to know if someone has made a purchase recently? I'm in the process of building an ACA.
Mayank
Mayank
I bought from them a few years ago. The parts were fine.
Thank you.
Just placing an order 😉
Rgds
Mayank
LSK389B/LSJ689 seem okay; probably not easy to match k to j, though. However, an LSJ689 seems perfect for Aleph J
> GR is fine for buffers.
Depends on what load and what max. output current you want to deliver.
If you can cherry pick 6mA Idss from GR then it is indeed not far from BL.
But then for buffer you can also use a pair of 2SK369V.
Patrick
To repeat back for confirmation, so I take it that for a 2SJ74 and referring to its datasheet:
http://www.mouser.com/ds/2/408/6903-18063.pdf
that with the following specs:
then a GR at an IDSS of 6 - 6.5 mA will be functionally equal to a BL of the same Idss performance?IDSS classification GR: −2.6~−6.5 mA, BL: −6.0~−12 mA, V: −10~−20 mA
Or is there some nuance in the numbers somewhere else on the datasheet that I'm not appreciating as being critical / important?
Sounds like I can make a GR work. The pairs I'm looking at are advertised with an IDSS of 6.2 - 6.4 mA and a match to 0.05 mA. They're destined for an Aleph J build.
In the first instance, I'm just after reassurance that I haven't blown my dough.
In the same vein, and from the perspective of expanding my understanding, the LS gear offered by the diyAudio Store:
Linear Systems LSJ74 Ultra Low Noise Single P-Channel JFET (8 Pieces) – diyAudio Store
uses "Grade" to differentiate the transistor classification, so:
LS A Grade ~ Toshiba GR
LS B Grade ~ Toshiba BL
LS C Grade ~ Toshiba V
The store's prices increase from C to A, so A grade appears to be the "best" if price is a metric but from what I've read here "A Grade" or Class GR is not the most useful or "as easily usable with minimal mucking about" for the Pass amp family. Just seems counter-intuitive at first glance to those at the start of the journey like me.
With any replies, please go easy on me. I've just built a pair of ACAs, so even though I might have kicked off the trainer wheels I'm still a bit wobbly.
Perhaps some references would be of help :
JFETs: The New Frontier, Part 1 | audioXpress
JFETs: The New Frontier, Part 2 | audioXpress
Patrick
Patrick
Patrick
Thanks for the links to the Borbely papers. I need to give them a solid second read.
However at this stage, I can't see that I'll have an issue with the plan I've got in place to apply the Toshiba 2SJ74 GRs to an Aleph J build. That said, I will be looking hard for the part where Borbely explains why this classification is worth a little bit extra over (say) the BLs. From a first read, I didn't pick that up.
Mayank
I went to BDent and bought two pairs of 2SK170/2SJ74s for a future M2 build. They "look" real to me but I haven't done any measuring yet.
An LSJ689 seems perfect for Aleph J; no matching required, 1/5th capacitance.... around $10 a pop (which is 2 X 2SJ74)
Kstagger - “matched” K170/J74 from b&d are not measured, just one of each from the same grade. Just FYI.
Linear Systems || ULTRA LOW NOISE P-CHANNEL DUAL JFET
That's $8.66 ea if you order 1000.
IDSS, by the datasheet, appears to be a nominal 14 mA or C grade. Maybe LS does a B grade version?
Certainly great to see another potential alternative.
And about 1/25 the transconductance.
Patrick
Patrick
And what with the IDSS grades? seems there is no category.
So you have to buy and it could be anything between 2,5 and 30mA.
Could be usefull or not...
or have i overseen something?
How did you arrive at 1/25th?
It seems it's "only" 1/5. The 2SJ74 increase in Idss will yield a (much) better return in transfer admittance increase, though.
The LSJ689 can still give 8.5mS. It can also be easily paralleled to improve on these numbers.
I struggled to compare both transistors; Toshiba and LS state slightly different graphs...
Aleph J steers the current through the 2SJ74's... 4.3mA, and 4mA
What about getting a group buy together for Linear Systems parts? I think the demand would be here to get pretty large numbers.
Thats why they sell them through the Diyaudio store
Have you tried buying a matched sj74's pair for Aleph J recently, from the store?
- Replacement For Toshiba 2SK170/2SJ74
