No DC or AC on outputs.
The Music That Makes Me Dance
You Won't Forget Me
Shirley Horn
sounds really relaxed, present and musical playing over my AckoDac AKD12, Ian FIFO, dual klock board, selected NKD wissler.straigth into a pair of nCore 400/SMPS600 and a pair prototype speakers.
Lets change DAC.
You Won't Forget Me
Shirley Horn
Lets change DAC.
No sound. No strange noise either. Dead silense. Now someting to eat.
For newer versions of the Amanero pins 17-20 are no longer ground but the sample rate indicator, see attachment at post (http://www.diyaudio.com/forums/vendors-bazaar/259488-reference-dac-module-discrete-r-2r-sign-magnitude-24-bit-384-khz-91.html#post419713).
As far as I can see from your pictures you seem to have conneted one of those pins to the I2S inputs of the DAC.
(Hence a wild guess: flashing green LED means no imput detected)
Paiging Sören.....
What does green LED flashing indicate??
Powered up, but not locked (no signal). LED turn steady when locked.
Make sure it's wired correctly and power is supplied to the isolators.
Dont know what happen there really but now there is 3,3 volt for the isolator. Still grenn blink.
I measure all OK on J2!
Check wires again. If everything looks ok, post a picture with both boards and wires clearly visible....
Cant seem to change 32 bit integer...
Can it be default Amanero Firmware configuration? (Red arrow in the attached screenshot.)
Sören, would this be a problem?
Isolators. Several? How to measure?
On the dam1021 R-2R DAC, measure power between "ISO +3.3V" and any "ISO GND".
- Vendor's Bazaar
- Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
