Ready-to-Run (RTR) SSR DC Speaker Protection and Delay GB
xrk971 / 76 units / USA
Monk55 / 2 units / USA *Pre-order Placed*
Nautibuoy / 2 units / UK *Pre-order Placed*
pinkfloyd4ever / 2 units / USA *Pre-order Placed*
MvonB / 2 Units / Germany *Pre-order placed*
Legis31 / 2 units / USA *Pre-order Placed*
mbrennwa / 4 units / Switzerland *Pre-order Placed*
s610adam / 2 units / USA *Pre-order Placed*
Baobei / 2 units / UK *Pre-order Placed*
meanie / 4 units / SG *Pre-order Placed*
wirewiggler / 2 units / USA *Pre-order Placed*
Thompsontech / 2 units / USA *Pre-order Placed*
Freiheit / 2 units / Germany
ricyuyc / 2 units / Hong Kong *Pre-order Placed*
Thank you everyone! This is a good amount of interest in this speaker protection circuit. We have 30 pre-orders so far and so that reduces my count to 70. I will place the order for production shortly. The BOM needs to be ordered and that takes about 2 weeks. Then they will build a "first article" for testing to verify everything is good.
xrk971 / 70 units / USA
Freiheit / 2 units / Germany *Pre-order Placed*
Hi Folks,
We are making progress, I just placed the order for the manufacturing to start.
xrk971 / 70 units / USA *Manufacturing Order for 100 units Placed*
Thank you MYL! I received a pre-order for 6 units from you.
xrk971 / 64 units / USA *Manufacturing Order for 100 units Placed*
MYL / 6 units / HK *Pre-order Placed*
Thanks, diytiger!
Preorder List update:
xrk971 / 62 units / USA *Manufacturing Order for 100 units Placed*
MYL / 6 units / Hong Kong *Pre-order Placed*
diytiger / 2 units / NZ *Pre-order Placed*
GB preorder update.
xrk971 / 58 units / USA *Manufacturing Order for 100 units Placed*
“AP” from Colorado / 4 boards / USA *Pre-order Placed*
Original board with dual mono power supply
Hi, I need a bit of help here please. I'm probably going to make a dual mono power supply for my quad 405. I'm going to use the original boards, is there a circuit to power these boards with a dual mono supply? I have made up a small board to power these (taken from this blog) and it works perfectly - instant speaker disconnect, but I guess this wont function correctly with a dual mono supply.
Dual mono is not an issue. I am powering both of my SSR’s from one of the secondaries of one of the two trafos. You can make two small low capacitance PSU boards and power each from the secondary of each trafo and it should work fine. I was lazy and tried powering both from a single supply and it worked fine - no noise or ground loop hum. If there was a ground loop, I would have had to resort to dual small low capacitance PSU boards.
I have an update from the manufacturing house. The PCBs are in production and will be completed by the 11th. Ordering of the BOM is taking some time as some items take longer to get in. Worst case scenario is that they will be completed by end of January. I am hoping sooner of the parts get in quickly.
Gen2 RTR SSR production progress!
Hot off the press! Here is the first article off the assembly line. I am waiting for the result of the functional test.
attachment.php
