Hello, ive buyed a QCC3034 CSR8645 and have a question about pairing name. Is it possible to change the name over usb or it is absolutly necessary to buy a spi usb programmer?
Is vchg everytime +5v. from usb? I have measured that the pcb is the csR8635 / CSRA64215 pinout, but with power connection from the pcb and only data + /- connected from usb cable my pc doesent recognized the qc3034.
Yes i was successfull to. Name change was possible. Have you an idea how a pairing button is possible? That the device is only for pairing when a button is pushed?
Not sure I understand.
If you linked it once, it will get connected automatically each time when paired device is in the range,
No other device have a pairing button that only allows new pairing after button was pushed.
Devices that was paired before can connect every time
Hello everyone.
I need help regarding the mde software.i burned the qcc5125 sink project from mde and it succeeded but in adk config the device is not showing.Can some one help me with this
Hello everyone,
I tried building a firmware in MDE, but I have encountered this problem:
Error: csr.dev.tools.flash_image_builder.CapacityError: Image for section ro_fs with size 614988 exceeds section's capacity of 327680.
Can someone help me reduce the file size to 327680?
I am new to MDE, I don't know how to program, and I can't find any tutorials online.
Thanks in advance.
Thanks in advance.
- Digital Line Level
- QCC5125 and QCC3034\QCC3031 programming
