Q17 - an audiophile approach to perfect sound
Finally joined the q17 club
I highly NOT recommend low ESR and low ESL capacitors on Q17 and in general on any analog design.
Sanyo Oscon are very low ESR capacitors designed specifically for digital applications. It will improve your low jitter clock, or digital reclocking circuit, but will kill sound of your preamp or amplifier.
Selecting the right capacitor for a specific application is science, but unfortunately on this forum is lot of voodoo.
Tibi, I checked the whole thread again, ...on your boards in C7 position you used Auricap XO as well as Mundorf MCap EVO SilverGold Oil.
I wonder which of the two will give you a better sonic result.
Thank You!
Use the CDC recommended in BOM. It is a top one at the right price and will fit the board.
C7 is placed in negative loop of OPA1641. Will contribute to dc blocking, but you still need to take care on previous stage to be DC free. C7 can not be eliminated, due output is lifted by Q7.
I don't see the reason why not to use low esr elco for decoupling purposes.
PCB's are at home.
PCBs look great, no visual blemish or scratch. I am satisfied!
I'm busy with work for the next week, but next weekend I'll finally get around to mounting the pcb. I plan to turn the Q17 into a design gem. The board itself as well as the transistors will be attached with golden screws. I asked Tibi about the sound difference between the Auricap XO and the Mundorf from the MESGO series, because I'm planning to choose between the two. But I'm leaning more towards Mundorf, in conjunction with pcb this combination will look really great. CDE looks kind of plain to me.
I also have the gerber files ready for the active PSU, which will go into production at the beginning of June. Gently modified for me by prasi.
Have a nice day 🙂
