Well, good to hear some positive feedback.It works just as well with the LM49710. The tweeter is a bit bigger. Here the Opus can be used as an equalizer ))
LME49710 is a modern and one of the best audio operational amplifiers. I would call it neutral.
In a very good audio system every component is audible and will leave his audio fingerprint. Operational amplifiers do NOT sound the same and you can use them to voice your amplifier.
Regards,
Tibi
My response was lost in this huge thread. On your board arrow indicate signal gnd....
Also can you also please confirm the polarity on the input signal socket which is the hot signal side and the signal ground as the confusion is with the small "Arrow" symbol near one of the pads?
#1,000
Regards,
Tibi
I retested the working board and I see around 312mV across R12 47/1W resistor and 283mV across R10 47/1W resistor with the offset remaining stable at 22mV. I checked now the offset between the circle output pad and the DC power input ground as the other speaker output pad is floating and not connected to anything as Tibi confirmed. Hope these values are good enough and I can hear the amp now on my test speakers.
Did you mean R10 and R12 right which is 47 ohm /1W right?@manniraj
You need to have ~3V across R10 and ~3V across R11.
Could you please measure again, otherwise check Q7,Q8,Q9,Q10,Q11,Q12.
Regards,
Tibi
Across R3/150R I get around 350mV and by the way my DC rails are around +/-32.vdc as using lower rail trafo of 22vac 300VA.Also check across R3 (CCS mirror) and R13 (Class A stage BIAS). You should read something around 550mV.
Regards,
Stef.
My mistake as I put a 100R resistor on the R13 instead of the 10R. After replacing I get around 3.15v and 3.16v across the R10/12. R3/150R I get around 377mV and then the R13/10R around 633mV.Did you mean R10 and R12 right which is 47 ohm /1W right?
Edit: I am using the 610/9610 instead of the suggested FQP mosfets for the information. So not sure if the IRF devices are making the lower R13 class A bias stage of around 377mV instead of the spec ~550mV as @stef1777 posted earlier.
Sorry, you need to have ~3V over R11 and ~3V over R12.Did you mean R10 and R12 right which is 47 ohm /1W right?
Over R13 you need to have ~ 550mV as Stef mentioned.
Over R3 also ~550mV.
Q17 will work with a wide range of vertical MOSFETs, so no matter much that you use IRF's.
Regards,
Tibi
Thanks Tibi, right now the above my voltages are with the input signal being shorted. But tomorrow will test with a 100R resistor across the input pins and then check all the voltages again. My only discrepancies is across R3 I am getting only 377mV whereas R13 is around 633mV still not to your spec of ~550mV. Lets see if I can get it close to your published figures and then hear the amp once tomorrow
Thanks Tibi, any idea about my low voltage across the R3 (150R/1% is what I used) of 377mv? What could be the reason as I checked all the resistors on the board and they are to the spec/schematic and no deviation.633mV across R13 is perfect !
Over R3 you must get higher voltage, at least 500mV.
Regards,
Tibi
I checked the hFe values of BS250 both of them and it shows around 617-622 on the board. I am yet to remove these from the board to test the Vbe using my LCR/mosfet tester. But in the meantime ordered few more pieces of BS250.
I ran this channel today and its playing beautifully irrespective of how the difference of voltages
Felt this sounds a bit different with good bold voices or if I can say more warmer especially the mid range and I am loving it.
The other channel I lost both the high powered mosfets and now ordered new set need to wait for a week or so.
If you like it in mono, than you'll love it in stereo.
Hfe on mosfet is a bit high to measure. Best tool to match and test a wide range of parts is something like this https://www.elektor.com/lcr-t4-mega328-transistor-tester-esr-meter
Regards,
Tibi
Regards,
Tibi
Thanks Tibi, I have something similar measuring tool but to do that I need to remove both the BS250 transistors which i am not good atIf you like it in mono, than you'll love it in stereo.
Regards,
Tibi
Can we test these transistors with probes/wires when soldered to the board and the amp is switched off? Or the real/actual figures can be measured only when its out of the pcb board?
- Q17 - an audiophile approach to perfect sound
