Pumpkin Preamp - Perfect for F4
Sorry ZM, I'm not following your question. Are you asking if I'm using a source? if so, then yes. Not sure what you are saying about the Aleph P.
Here's a pic, not that it shows much except the Pumpkin colour.
I understood that ZUM placed caps between pot and Pumpkin input ...... and he aslo put 47K from Pumpkin input +cap node to gnd , to load that node more
pops are still there
if they are , then pops aren't DC issue on Pumpkin side , but on side of attenuator itself
ZUM - what's feeding attenuator ?
edit - I mean - is there any DC going in attenuator itself ?
Thanks guys. I've tried 2 different sources both of which have negligible DC offset. I've also grounded the the inputs on the attenuator with same results.
Generg, sorry, I misunderstood you first suggesting the caps at the attenuator input.
Correct me if I'm wrong but if I ground the inputs without the source attached that should eliminate the source DC issue?
The DC offset may not be negligible in that case..... Try a cap between source and attenuator to get it out.....
try to find something like this - dirt cheap ( say 20E) and hard to beat with anything up to 10x price
must be smd resistors , ladder if possible
one "stereo" per channel , or try to find balanced (then 4 decks , no ladder)
keep it in close proximity to inputs , extending shaft is way to go
either that , or AVC as next possible and worthy step , but they're mostly intended for SE arrangement and , frankly , I didn't tried them (yet) in floating balanced mode
Generg, I get the symptoms with and without a source with caps installed before Pumpy. Also with inputs grounded, and caps installed at Pumpy input.
Incredible....!
Of course it is now the time to say again the the sound comes from the attenuator.
Does the attenuator use a separate PSU?
Are the grounds of this PSU and Pumpkin connected?
Maybe you wrote this already.....
I just didn't want to answer with depressive silence ......🙂
You mean the attenuator? I have the same in the Aleph P. I exchanged the control boards to test since that was easy with same results. It's not worth it to me to continue trouble shooting this. I'll source another volume control. Thanks for your efforts in helping.
Cheers
Rick
ZM,
While looking for a alternative volume control I had a go at my new to me oscilloscope. I think I'm finding oscillations in the Pumpy. I've attached photos showing a 1K square wave and then of the 1K up close and the last one is the Pumpy inputs grounded. What ever it is it is the same frequency so I don't know if it just noise or there is a problem. The scope is at the end of it's adjustments, .2uS and 5mV with x5 setting. I see the same results all up and down the volume control settings as well as grounded inputs.
Rick
You're getting something in the range of low MHz - generally I have found that poor wiring on the bench induced positive feedback around an amplifier produces oscillations in the few hundred kHz range. To get oscillations in MHz range I found it more likely to be quite localized to an unstable feedback loop on the circuit board itself, possibly via the power rails or the grounds. Are those heatsinks grounded ? You could try taking a board or two out of the chassis and separating them a bit to see if some local coupling is the problem.
Once I had similar very low level oscillations at the limit of my scope and it turned out not to be oscillations from my amplifier but from another source (another piece of test gear or a nearby appliance - there are lots of sources of 'environmental noise' around my house, including my CD player) that was getting picked up by the scope probe or grounding. The oscillations were still there when my amplifier was not powered!
Hi Bigun,
Thanks for the help. No, the heatsinks are not grounded. I've actually probed them and see the same oscillations. It could be environmental noise. I've done what I could to eliminate as much as possible. Lights off, just the scope and Pumpy on. I'm in my garage and there is nothing else on the power circuit.
