Manu said:
Magura : I was just asking about alternative thermal coupling solution with "metal" tie... which I don't know.
But its long ago
and now thema is drilling and tapping.
Thanks for replay.
Manu
look for Jaccovitty's pics
narrow sheet of Cu or Al tin formed as O
The brass things i posted (P789) are not DIY, they're serial production heatsinks for 92s.
The bottom edge is flared to add some spring resistance that makes them clamp the little ones and not slide down slowly.
Making them like that is not all that easy, you'd have to machine a 2-piece mold to press the flare.
The easy way would be to fold a thin strip of brass/copper around the devices, then tighten it with a chica plastica
(Ruben Blades: fav. actor and all-time abfav. salsero)
Leads have a considerable effect on the cooling factor of semis/resistors, from that on their operating temperature.
(for lesistols, the distance to the PCB is also vely impoltant, read a tech paper on lead length and mounting height from e.g. Vishay)
An amp case needs to be ventilated, the airflow within the case is not a stasis situation.
Most of the cooling will take place at the top of the Baldricks if the leads are insulated with teflon leggings, more uniform
Some day i'll get the matches back to Guernica
jacco vermeulen said:The brass things i posted (P789) are not DIY, they're serial production heatsinks for 92s.
Manu said:Thx a lot Jacco
I post this your pic again ( If I may)
Interesting too are the isolation of zistors legs ,
I didn't notice it the firts time a saw the pic.
Very nice and accurate work.
Manu
someone here have short memory
lazy greedy boyz
lookie lookie
and - makin' these Jaccovitty cool stuff is POC - you don't need even to make that skirt of one edge
http://www.diyaudio.com/forums/showthread.php?postid=1237712#post1237712
http://www.diyaudio.com/forums/showthread.php?postid=1237714#post1237714
http://www.diyaudio.com/forums/showthread.php?postid=1244829#post1244829
http://www.diyaudio.com/forums/showthread.php?postid=1244830#post1244830
ya can do it that way too ....... even nicer
edit - for Manu :
just a little memo :
http://www.diyaudio.com/forums/showthread.php?postid=1247765#post1247765
Choke,
i could not find one without hair so i knicked yours=>
ya nutz
spavleski said:Pumpkin first run...
I'd wipe off some of the excess thermal goop.
Looking good though 😎
Magura 🙂
hershann said:Are terminal blocks to allow easier testing and rearrangement of configuration a bad idea for audio pcb boards?
her shann
good idea - for testing
remove them later ...
For Shunty C17/a & C18/a - was listed as 10n ceramic cap. I have some extra 10n film caps lying around - is it alright to substitute with the film cap?
her shann
her shann
hershann said:For Shunty C17/a & C18/a - was listed as 10n ceramic cap. I have some extra 10n film caps lying around - is it alright to substitute with the film cap?
her shann
yup .
hershann said:substitute with film cap
Better any cap across a rectifier diode than no cap, stuff like distortion figures and tolerance don't mean sheet for diode damping.
Cheapo cookybookie says better add some ceramics on the next orderlist, Z/X/NPo ceramics are superior to any film as rectifier bypass and cost mucho less.
(esoteric pric-picks an NPo/COG, 3.9pF-100nF)
her shann
I usually let them sit for the PSU connections. Its very convenient when you have to take it apart. For the signals its mucho better to solder the leads directly to the boards.
Is it true for any kind od Rect.-Diode?
Shotky, Soft recovery, ultrafast etc...?
Manu
Je commande?
Very high efficiency speakers. . .
While waiting with eager anticipation for the Pumpkin/Shunty boards, I've been collecting parts out of my junk boxes, and figuring out what I need to order. However, I'm thinking that I may not need the truly manly voltage swing of the Pumpy/Shunty into the F4 with my 106db/w/m DIY Edgarhorns. . .
I've followed the threads on "how" to lower output, but what is stumping me is "how much" I ought to be considering -- I don't want to be running the volume control just cracked open. A pot can be touchy enough, and with stepped attenuators I've found that it is *always* one click to soft, the next click too loud. . . 😱
I currently run the Edgars with a Brenneman cathode follower tube integrated with a whopping 10 wpc, and usually never have the volume control more than 1/4 open.
Suggestions? 😎
It would be nice to have a volume control with very fine control down where I actually use it, and I don't care if it makes 6dB steps at full volume, 'cause it never gets close to that high!
Thanks for your time -- and thanks for the most interesting and entertaining DIY threads I've ever come across. 🙂
Steve Z
near Libby, Montana USA
Suggestions? 😎
Steve Z
Re: Very high efficiency speakers. . .
did you downloaded Cook Book ?
http://czsr_bac.on.neobee.net/The Pumpkin & Shunty.pdf
just say -yey or ney , and I'll answer , or will not ........
edit :
it's really not important did you downloaded it ; what is important - did you read it ?
zettelsm said:While waiting with eager anticipation for the Pumpkin/Shunty boards, I've been collecting parts out of my junk boxes, and figuring out what I need to order. However, I'm thinking that I may not need the truly manly voltage swing of the Pumpy/Shunty into the F4 with my 106db/w/m DIY Edgarhorns. . .
Suggestions? 😎
Steve Z
edit :
Cookbook/gain question
Yes, I did download and read the Cookbook, (and I thought it was a great thing for you to do). I believe I understand the "how to" part of lowering the gain/voltage swing of Pumpy. But maybe I missed something. I've had the flu for the last couple of days and haven't been in my right mind.
What I am not sure about is "how much" to lower the gain. Or perhaps I don't need to lower it at all. I don't mind using the lower part of the pot or stepped attenuator, so long as I have enough control over small adjustments without always hunting and being too loud or too soft.
I tried a a well-thought-of Chinese 2A3 integrated amp a while ago with my DIY Edgarhorns, and besides being unacceptably noisy, it was too loud at the third click of the stepped attenuator.
So maybe all I need to do is figure out the right range of potentiometer. I remember reading that a lower value is theoretically better for performance
Am I barking up the wrong tree? 😕
Feel free to heap ridicule on my head!
Steve Z
Libby, MT USA
Steve Z
Libby, MT USA
- Pumpkin preamp - More Boring Making Thread
