Protection cap for my precious new compression drivers?
If you ask me, my active setup was driven by 3-way Hypex Fusionamps, that was the setup with the capacitor test too. The tweeter was a CD+horn with sloping down frequency response towards highs, so in theory it was logical to use a capacitor to get a more flat fr response to begin with, plus in theory it provides a better protection for the high fr driver, but we can see from previous replys that the extra protection is not necessarily true in all cases.
Anyway, if the capacitors had a transparent sound, they would have stayed in the signal path, but I didn’t hear it that way. The same happened with an L-pad to passively reduce the tweeter level.
Yes, I know what an L-pad or a capacitor do to the responses, even the subtle ones. As I sayd, the final frequency/phase/timing responses was the same with or without the passive elements, it was not too hard to achieve thanks to the DSP.
I thought we used active filters because:
- they're more efficient - less amp power wasted
- higher order filters are practical
- you can change a crossover frequency at the gig(!), 5 minutes before the 1st tune if necessary - very flexible
- time alignment is practical (DSP crossover or digital amp) - can't with passive
Also eagerly awaiting the reports/impressions on the 18Sound Be CD's.
Cheers
Amp are very efficient. Speakers are not. Best to add more speakers.
I don't do gig. I don't understand why you need to change crossover at a gig.
Do you walk around the venue to measure fr and then tune crossover for time alignment?
Seems you and I don't have the same thoughts.
It's rare to adjust crossover frequencies at the gig. Maybe subs to mains, depending on positioning etc. If the subs are centre clustered away from the mains, it can be best to drop the crossover point to shorten the effective path difference.
Time alignment, however, can vary venue to venue depending on the physical speaker placement etc.
Even then, the mid-to-high alignment is generally fixed on account of those drivers typically sharing a cabinet.
Chris
A quick update for anyone who may be having the same issues with turn off thump. I can confirm that the DIYA speaker protection board works perfectly when powered from it's own separate small (I used 7VA) AC transformer.
I previously tried them powered from the amp PSU and a small Meanwell DC supply but it takes too long for the caps to discharge.
Hi, mpa
I too use valuable tweeters, the TAD ET-703's, which also has a beryllium diaphragm and nearly unobtanium today. Unless I missed it, did anyone suggest a 1/2 amp fast blow fuse on the tweeter ?? I don't know if that is the ideal solution but that should work---for home use. Seems like many of the solutions here will downgrade the overall sound.
I once disconnected a field coil power supply ( while powered ) wires from a driver above the tweeter and the wires fell right across the tweeter terminals, the diaphragm literally blew to pieces !!
It took me a year and $800 to find another diaphragm !!! Needless to say, I am much more careful to make sure the power supplies are turned off when removing the wires. Good luck with finding your best protection solution.
Meet Joe, and his amazing DIY horn speakers - YouTube
Joe
