Pros and cons: prime MM\MC phonopreamps "X-Altra" & "LP797" vs "Cy-XXI"
Do you like to listen to sweep tone? Please, Ortofon test disk sweep 800 Hz - 50 kHz through a cartridge with a spherical stylus and my phono stageView attachment 1224948
It is well established that you can take a cart + load capacitance and tune it for a flat response. To be able to do that you need a test disc (which you have) and some test gear. Bob Cordell’s VinylTrak and Hans Polak’s investigations amongst others are examples as is Burkhardt Vogel’s work.
The real difficulty is being able to replicate that trick across different carts and load capacitances without recourse to test equipment ie the average user experience. In that case, the optimal loading is 47k and 100-300 pF.
I would advise you to ignore Wayne Stegal since he derives the wrong formula for the cartridge Q. The correct formula is on page 411 of the Radiotron Designers Handbook and I attach it. You can't just start committing algebra on the transfer function without knowing what you are doing. I told him the formula was wrong, but he hasn't corrected it. The correct formula is given by equations 22 and 21 and they can be simplified to Q=Rl*sqrt(C/L). Note that figure 9.4 is the simple model of the phone cartridge and load.
Reactions: Bonsai
The thing is Nick, post #164 above notwithstanding, you still have to enter cart L, R (ok - you can get that from the datasheet) but how does the user know what the cable capacitance and the amplifier input capacitance are? They don't and that has a critical bearing on the overall response.
In that case, the best way forward is to start with the 47k and then just tune the system for the best sound by adjusting the load - ie highly subjective but quite ok IMV since at the end of the day this is about enjoying the music.
With a 150k load and 10-25pF load capacitance, you still have up to 2dB anomaly at 20 kHz given typical modern cart L and R. 150k R load and very low capacitance requires a very specific set of implementation conditions and knowledge of the cart L and R and actual load capacitance, much like difficulty MM phono stages that feed into summing junction type arrangement have in dealing with a wide range of carts.
There is a reason the industry settled on 47k + 100-200pf: it gives the best overall response over a wide range of cart L and R. Below is the plot of Cload stepped from 50pF to 200 pF
I see only about 1 dB, which is a great result.
There is only one reason - to allow the user to connect the cartridge through the cable. If we exclude the cable, you can do much better matching.
Separately, how many people have a setup with 0 pF cable capacitance?
The load of 150k is suitable only for those who do not have a cable at all, and the preamap is installed near the tonarm.
However, I found that at least for some cartridges, C is needed to correct the FR of the mechanical system.
So far, no one has yet introduced real measurements of the test LP with the load of the cartridge 150K, where the correction is needed.
The whole point here is how many systems in the real world are like this? 0.5%? 1%? Who is going modify an expensive turntable like this? If you are a DIY guy with good skills, you might try it, but for most, they won’t take the risk. And high end commercial brands won’t do it because their customer base don’t want to be tied to a single phono amp solution.
The challenge surely should be ‘how do I create a SOTA preamplifier that can accommodate real world setups?’
Nicks design is full of implementation constraints that most people cannot meet. 0 pF cable capacitance, resistor cooling, ‘A’ weighting, special IEC measurement methodologies etc.
This is not the place (between two red dots) where the Johnson noise curent generator is located. It should be in parallel with the 47k resistor as explained here.
The noise current generator of 47k resistor is located in parallel with 47k resistor, and noise voltage generator is located in series with 1k cartridge resistor. Don`t you know Thevenin/Norton + Kirchhoff ?
I said with a range of cart L and R typically found in the market, not just the .5H and 1k R you and Nick use
See 150k + 25 pF for Lcart stepping = 250...1000 mH without any adjustment. That is 95% of MM carts. And that is a fact that you do not need any test disk and voltmeters/oscillo. Simply unscrew the 4 screws on the bottom panel of your turntable, solder 6 wires and screw the 4 screws back. Any DIYer can do it in 5 minutes, and ordinary housewife, after she finds out which end of the soldering iron is taken 😏, takes no more 15 minutes
