PPI PC21400.2
In differential mode here is what I get .
Pic 1 is of Q1 Pic 2 is Q2
Pin 16 of the 3525 is 5.09 volts
Pin 15:13.74
Pin 16:13.74
This is for both 4081’s
I was cleaning my bench off at the time and disconnected the probes so I only hooked one up to test this amp .
But to me it appears Q1,Q2 have good drive signal .
Q7,8 now have issues with drive should I go back to a cap in differential mode and post the waveform I get ?
Ok here is what I get for drive signal they locations are loaded with a 1000pf cap
First pic is Q1
2nd:Q2
3rd:Q7
4th:Q8
Scope is set up in differential mode
Put all the fets back in circuit along with the rectifiers and regulators .
I powered the amp up for a couple of secs out of the sink and tested for output everything seems fine right now .
I’m gonna put it back in the heatsink and fully tested it .
I will let you know how it goes
