PPI PC21400.2
Anyone have a pic of this area ?
I’m working on this amp again .
Does anyone has a close up pic of this area or the bottom side of the board ?
Leg 1 of the transistor has no trace going to it since it was burnt off the board .
I can’t seem to figure out what leg 1 of that transistor connects to
Not sure what the board location is . Since it’s burnt in that area .
The other side of the amp is pretty much the same circuit and Q60 is an A56
Here is a pic of where the transistor goes it sits in front of CR17
Replaced the Hip4081 ic’s and on 2 banks of fets I get no drive signal .
Do these have a high failure rate also like the 4080’s ?
Or any ideas on what worse to check since I get no drive at all on 2 banks including Q1,2,3,4,5,6 and Q69,70,71,72,73,74
I have a nice square wave when the ic isn’t loaded as soon as I load the 4081 with a fet the drive goes away
