Post your Solid State pics here
ejtsoundsystem said:
CAN YOU SHARED THE SCHEMATIC DIAGRAM FOR THAT AMP???
Please, not in common view.
The reasons are:
1) I don't like the appearance of some people here, who looks like the two old mans Statler & Waldorf on the balcony of Muppet Show to criticize for kidding - after they have drink enough beers - ( DO YOU HEAR Mr. MODERATOR??? ).
2) There is in my country enough electronics who many times they copied my plans to make money with succes.
3) I make this job for living - not for hobby.
4) My plans are not so much exceptional, the only that i make well it is the correct pcb drawings and the use of first quality parts.
So, to facilitate you, please send me e-mails with your link to post you the plans privately.
Fotios
The reasons are:
Fotios
I know what you mean .. fotios.
Some can not even say: Thanks 🙂
when I publish my job from a circuit design & post it here
Very bad 🙁 Bad people ???
Re: Re: Yap
fotios said:
Also if it is easy, an indicating photo from your scope screen?
I've been lately extremely busy with my dayjob - I'm afraid I have to delay publishing the new amp on my web site.
Here's a quick snapshot of the YAP amp pulse response in a capacitive load.
- 10Vpp 500KHz pulse.
- 4ohm || 100nF load.
- Zoebel network is in place: 10ohm+100nF
- 0.6uH (damped by 4.7ohm) output coil.
Upper trace is real time, lower trace is delayed sweep (magnified trailing edge).
Nice amp (yours) BTW. If I would have the same talent, pacience and time to lay out PCBs as yourself I could probably save a little fortune in PCB costs.
A better photo of the finished OPS:
Re: Re: Re: Yap
stephunk said:
Hello all, this is my piece.
Originally designed DPA330 by Pavel Dudek, big thanks to him.
syn08
Your YAP is a very good amplifier .. and you know it 😉
stephunk
Pavel Dudek has made some really good amplifiers.
I am sure your amp is playing some very good music.
Dudaindc, not exactly, protection circuitry still missing. But soon will be completed, also front panel is completed and waits for assembly.
Syn 08-well done, very nice PCB. Amp looks to be stable. 2 Months ago, i tried the Alexander amp construction. Now i´m working on PCB, because original PCB looks awful, separated output stage etc..my prototype board worked very good, afer some little changes(-3dB at approx 700kHz in 6.6Ohm). I want to use it for driving the tweeters on my 2way system(nowdays completing).
Changes: in output stage the IR fets were used, Ne5532 on input. Also protection circuitry was added. Whole thing will be placed on single PCB-i hate cables..If the day had 25hours at least😀
greetings
And the rear of the NX150. Conrad heatsink, WBT RCA and binding posts. The cases had to fit a particular size (non standard), so I was limited as to what cases were available. In the end I designed them using Front Panel Express' software.
Inside the amp case (as per photo on previous page) is 1 x Aussie Amplifiers NX150 module, custom 400VA potted toroid, 2 x Mundorf 47000uF/80V caps, Borbely speaker protector and my own soft start/switch on board. Now to finish the 23W subwoofer...
Do you have a picture of the inside? How did you fit the Mundorf 47000uF/80V caps? to the PSU? or to the amplifier module?
Here is a pic of the inside (top view) showing the transformer, caps etc. I designed the case to have a sub-panel. All the electronics mounted on this and this subpanel was then bolted to the bottom panel with 9 standoffs.
