Post your Solid State pics here
Hi Mooly, It depends how big is the peak current you need to forward. In my amp it is 28A so six pairs of output devices. The limiter treshhold is setup arround 33A. The inrush current is hudge, but thanks to a very gut toro specially designed for audio, and a soft start cirquitry the inrush is not blowing an T4Amp fuse fo industrial type 38x10.3mm. The softstart limiting resistor is 10 Ohm 40W shorted arround 500ms after switched on. Regards.
At last I got the chance to take a pic of the inside of my little "test rig", as I have decided to make yet an update....
And I know.... I have to do something about the wiring 🙄
Started out as a simple stereo buffer, but more end more circuits where added over time 😀
Now it contains two mono buffer circuits and two mono analog input selector switches, all with their own regulated supply :bigeyes:
So obvious the toroid had to leave the chassis, and are now placed in it's own small chassis.
When do I learn to start with a larger chassis? I always end up with a crowded chassis :whazzat:
NMOS internal
OK...QUASI made me drag out the camera again 🙂 So here is an internal pic....redesigned the boards to use two IRF240 TO-247 per side....of course using QUASIs layout made this easy ...
