Playstation as CD-player
Funny... I was thinking of eventually doing separate regulation for the DAC, but for the rest, I'd need a service manual and I haven't seen them around yet.
http://www.eserviceinfo.com/
Search SCPH,
there's the SCPH-7500 manual for free. (just found it BTW)
If you want the 1000 series one it's here:
http://www.user-service-manuals.com/Sony/SCPH.shtml
Edit: This one has the DAC in the DSP.
And they DO have the good laser tracking adjustments.
It seems you need a special disc.
The voltage is 8v and 3.3v finally.
There's a 5v regulator on the mainboard.
Re: PS-Power Booster
pieroh said:
Hi you all,
I am afraid this is a little bit off topic...I built a flee power SE amp that delivers 2,5W into a 4 Ohm load. My PS is directly connected to this little amp. Realy good sound with my highly efficient ESS-bookshelf speakers.
Nice Easter Holidays and happy listening!
Peter
Hi peter,
very nice ! Can you give more detail of the speakers ?
Re: Re: PS-Power Booster
jives11 said:
Hi peter,
Hi jives,
the speakers are original ESS-bookshelf from the seventies with the legendary ESS air motion transformers (a patented design by Oskar Heil) and a 30cm bass woofer. The speakers have a efficiency of around 93dB/1W, so 2,5W are prettty loud.
I refurbished the speakers some years ago and I will post a photo tomorrow.
The tube amplifier works without any silicon, tube rectification EZ80, ECC85 driver stage, EL95 output and without global feedback.
Sound is very nice not like a soundblaster with a tiny stereo IC-amp!! ;-)
Peter
jives11 said:
Hi peter,
Hi Jives,
this is for you: ESS-bookshelf
Peter
Search SCPH, there's the SCPH-7500 manual for free. (just found it BTW)
DM,
I was a bit confused at first, but after re-reading your comments and edit, it sounds like the edit refers to the SCPH-7500. Correct?
I just want to be sure before I plop down some bux for the SCPH-1001 manual.
Greg in Minneapolis
Hum.......
Hey guy's, I'm just about to dive into my 1002 now that my amp is finished and have a quick question.
I've noticed that there is a hum on both channels, has anyone else noted this? Also, would the output bypass mod cure it?
I wondered if it was some kind of ground loop, are the signal grounds tied together in the Playstation?
Any help would be much appreciated,
Cheers
Lee
Re: Hum.......
Cheers
Lee
my PS is dead quite even when connected to a valve amp with rather high input impedance, which is ideal as the output of the PS is not loaded so hard.
Are you sure the hum is from the PS and not from your amp. Check your amps grounding, did you starwire everthing?
Is there only one connection to chassis ground?
As Mick mentioned before, the input impedance of the amplifier following the PS should not be lower than 47k.
My suggestion is to get hum free before you start to modify the PS.
Peter
Re: Re: Hum.......
Peter
Thanks for the reply Peter, I don't have a ground to the chassis as this has a safety earth for the PSU. All the input wires are shielded to the pot (100K) and to the board.
The thing is, if I connect my old CD player it has only a very, very faint buzz and my MP3 player has none what so ever?
Thanks anyway
Lee
Re: Re: Re: Hum.......
Thanks anyway
Lee
PS not also connected to anything else i.e a TV ? Just a thought.
Re: Re: Re: Re: Hum.......
Nope! Just the amp.....????
I did notice this with my old amplifier but that was before I conected it to my highly efficient MLTL's and now I realy notice it!
This impeadance thing has always baffled me, what if I do the bypass mod with 100K resistors?
Lee
I currently only have a tube amp, about 40 years old. But I used to play the PSX on a more recent ss amp as well. No hum. No nothing. Well, there's very low hum from the tube amp if you put your ear to the speaker. (Do normal people press their ears to their speakers?)
I assume the impedance differs, and they do sound different. But I wouldn't know if the difference is related to the impedance or the amps themselves. The tube amp does sound "fuller," which is the thing I like about tubes and vinyl as well as the PSX.
I'm currently scouting for a new amp, either chip or class D. I don't expect any impedance-related problems.
[y/n]? Y
If you want to take the time to find the topic where I compared the A/V multi out(No opamp) and RCA outputs(an opamp), you will find the answer. I'll tell you. It's the buffer stage(With all the hum probably caused by the PSU or something like this). So, yes, the bypass mod solves this.
Maybe you have a different kind of hum, but bypassing solved my problem.
Note that I found that hum by putting my -120dB S/N amp at max volume while on pause.
