Playstation as CD-player
More...
Wow...that's great.
Would there be a way without Boot-CD, I think this would be perfect.
Are you planing to show the schematics and source-code of the µP?
Marc
I believe it's possible to boot directly from cartridge without boot-cd, but I don't have enough skill's to do that. Maybe some day.
I probably will release schematics, but I have to first draw it. Now it's just in my head. Also source's after I clean them, it's a mess with all test crap.
Some day.. 😉
Hi everyone!
Thanks to this thread, I've managed to get a 5502, planning to mod it.
So far, listening through it's multi AV connection, it sounds great but comparing it to my m-audio 2496, there's one thing I'm not happy with: hiss noise. It's clearly noisier than my sound card, just the hiss.
Other than that, the sound is really promising.
My question is: anybody thinks that applying the output circuitry mod will lower the noise?
Or maybe it's from the power supply and I have to replace it with a linear one?
Many thanks!
ha ha ha .!!! you need a av cord which fixes a little tighter in av port of the console
check different av cords . that noise is due to loose connectivity but please dont
pressurise the av ports steel it will get loose even more .try 7001 cable in your 5502
i ve done it and the noise just disappeared . the problem is just earthing fixing with
a comfortable precise tight connection . enjoy !!! hope this helps....
I wish to use top end capcitors, can anyone instruct me how to and obtain Mundorf Mcap on the PS1. I see the tutorials on that site, but I've seen some really nice setup here on this site. I hope some of you professionals can show me some detailed pictures and what I need to make this project work. 😀
PlayStation CD-Player, May Day 2013 release
PlayStation CD-Player with 16x2 lcd-display
PlayStation Serial -->-- MSP430 -->-- HD44780
Burn cdplayer.cue to cd with ImgBurn.
You need modchip to boot burned disc on PlayStation (or use swaptrick, or some other way..).
Use Energia IDE with MSP430 LaunchPad to program your microcontroller.
Controls, Gamepad 1:
X - Play/Pause
[] - Stop
R1 - Next track
L1 - Previous track
R2 - Forward
L2 - Rewind
Start - LCD Timemode, Track/CD
Select - TV mode, PAL/NTSC
Files:
PSCDDisplay/PSCDDisplay.ino - Sourcecode
PSCDDisplay-schematic.png - Schematics
cdplayer.bin - cd-image of CD-Player bootdisc
cdplayer.cue - cue for cd-image
readme.txt - this file
Links:
MSP430 LaunchPad Value Line Development kit - MSP-EXP430G2 - TI Tool Folder
Home \ Energia
The Official ImgBurn Website
- SCPH79, May Day 2013
Download: PlayStation_CD-Player.May_day_2013-SCPH79.zip
PlayStation CD-Player, May Day 2013 release - YouTube
Passive preamp
I am using passive preamp Sonus Qualitas pvvm1. I modded a SCHP-5552 today and made a bypass as described by Mick Feuerbacher. I am using 10uF capacistors and 4,02Kohm resistors. I believed that the caps would eliminate the DC from the AKM, but nope. I have tested with a buffered preamp with decouplers and that sounds good. What must I do?
