Maybe you could borrow one, no need to buy one. Anyway try to create some safety measures before you power up your new toy!
Yes,you are right.
My voltage doubler will be insulated ,and i will use a variable power supply.Pictures will come as soon as possible.
Use fuses with a reset funcion. You will need those. Good luck and share some pictures with us!
Hello,
i have a new question ,please:
What's the impedance of the electrode?
It's like an antenna ,isn't it?
I can calculate the impedance of RF choke and oscillator coil and capacitance.
But how i do to find the electrode current ?
regards
regards
This would be difficult to determine as when the plasma is produced the impedance will change plus it is depending on the construction of your device/electrode as well.
Hello Lampie 519,
Thanks for reply, your help is precious.
Would you like to have a look on my schematic.
Modulation is not drawed. I'm In doubt about L1 and L2:
is L1 enought ?
For me L1 seems the hotest coil.But for all plasma speakers the L2 coil former is build whit ceramic.
If L2 is the hottest of both coil,why?
regards
Have a look too on my voltage doubler:
C2:
Both get hot! I don’t understand C3. It should not be there! This should be a choke nothing else. Please see the schematic i have provided earlier.
It is nice, just a lot of tubes. Try the simple version first as it is difficult enough to get it stable!
Work In progress:
- Planars & Exotics
- Plasmatweeter
