plasma tweeter
@bernard,
I have seen some pictures of your plasma tweeters. Do you have some more information regarding your speakers? I know you have solved the ozon problem with the high temp in your speaker. You use some kind of horn. What schematic do you use and what does your flame thrower look like?
Nixie said:
Horn-loaded corona discharge... UGH
Horns ALWAYS add coloration and are a cheap way to extend the bottom of the frequency response.
Corona discharge is inferior to glow discharge, but much easier to get stable.
Ummm... no. Horns do not ALWAYS add coloration. Much depends on two big factors: the inherent distortion of the driver and the HOM (higher order modes) for a given horn + driver combination!
One can make a horn with frighteningly low distortion and nil coloration. It's just that most examples that are found do not fit that bill. The addition of "coloration" is not an inherent quality of all horns by any stretch of the imagination.
_-_-bear :Pawprint:
Yes it was, as a matter of fact, but I posted it for a reason. When I was building these tweeters, I was thinking along the same lines of using fets. I was following a project at some uni where the students were designing one from scratch. It wasn't finished.
Today whilst searching, I couldn't find the project I was following before, but I found this one, and it appears to be more complete than the other. Maybe it is the same one.
I didn't follow up with that project, so I can't help you further 🙁
FWIW, I had the occasional red plate which IIRC was related to the coil. I experimented with various windings with various results. Your flame does look good. I feel you could extend it maybe 2-3 times in length and present a better load to the output device.
Your windings are very close. This creates a high interwinding capacitance and the resonance Q is less than optimum. You may have better results if you leave a 3-5mm gap between each winding. I would keep the same number of turns.
Nixie, that's a pretty impressive block of work you've done 🙂. Where could I find the latest info on it?
Hi Indm,
thank you for reply.
I will try today 3-5mm gap between each winding and make report.
Ceramic base i got as sample of one ceramic factory here in Slovenia.
I attach one foto more, if someone would interested to build.
This is just test setup. I plan to build maybe with alu horn.
regards, Bostjan
yesterday i tried with your sugestion of Tesla coil.
Distance between windings was 5mm.
Flame gets 2x bigger and efficiency is also better. javascript:smilie('😉')
wink
Music is now louder than before.
But still tube is getting red after 2 minutes.
Is it related this to the tesla coil?
regards, Bostjan😉
