Pictures of your diy Pass amplifier
after some tweaking...
It seems I can get the values into the ballpark?!
-3,7mV DCoffset (at speakeroutput) is good. But I ran out of wiper at the trimpots to bias higher.
I have to change some resistors... The adventure continues.
Cheers
Dirk 😵
Enjoy every day in these crazy days... Listen to some good music!
Reactions: Soundhappy
Hello out there,
i have biased the 'baby' to 400mV over the 0,15 Ohm resistors. So I am at around 2.67 A.
After 30 minutes I measure around 38° C at the outside of the heatsink (where the Mosfets are inside).
I am a cook... :scratch2:
Cheers
Dirk
Hello ZenMod,
I think it is solved. I have made my own bias-boards. The circuit is very close to your Babelfish XA252-
OS-bias-circuit. I have used ZETEX NPN and PNP for the Wilson-current mirrors. I also had to adjust
some resistor values. I have to say - I copied from you! Offset is at the moment around 5 - 10mV after 30 minutes. At startup larger. Will see what the speakers will say at switching on? - Oooomph :redhot::bomb:
Perhaps I need my first speaker-protection - boards?
Second channel is also biased up. Have to add input RCAs. Perhaps a little listening test this night -
or tomorrow.
As we all know - patience is our friend. Especially if we seem to see this :c_flag:
Cheers
Dirk :drink:
Hello sound-gourmets,
Dirk is very happy! 🙂 The IXYS-Mosfet-monoblocks are up and running.
I am listening to music out of this aluminum-excess.
Have a peaceful sunday!
Dirk
Reactions: audiosteve
Hello ZenMod,
DCoffset at speakerout is at switch on around 150-200mV, but immediately goes down to around
40-50mV offset. After warm up (min. 30 min.) it is anywhere inbetween 5-20mV.
railvoltages are +-31.4 V DC unloaded and +-28.9 V DC loaded. Ripple voltage at the PSU was 0.4mV
unloaded and is now with 2.67 A of bias at around 18 - 20 mV AC.
Temperature at heatsinks is around 38° - 40° C.
No nasty blops. I am listening at the moment in the listening room...
ACP+ as preamp and those two 'big blocks' behind.
Cheers
Dirk 😉
I forgot - some porn...
