Pictures of your diy Pass amplifier
If your cutting metal with a wood blade on a table saw , turn the blade around. You don’t want the teeth cutting into the metal, you want the blade to turn backwards for this. I have cut miles of metal roofing and steel with a Circular saw and table saw and found out very fast that you need to run the blade backwards. Or the teeth will start flying off the blade
My diy camp amp
Hi guys . Just finished my diy camp amp
Awesome - does it fly with that many fans? :D :D I'm imaging something like the world's first quad-copter-ClassA amp.
In all seriousness, it looks like you have an amp that will stay nice and cool - a major accomplishment in this arena! These amps are addicting: I have one in my office that runs all day long every day and my kids also have one for a small bedroom stereo.
Joined 2007
Here's the ACA I built from the boards I got from Burning Amp 2017, then I brought the finished amplifier back for Burning Amp 2018. I assembled it from a lot of surplus parts I had on hand, and I put the surplus 24V SMPS inside the chassis. I was worried about noise (SNR >90dB) and crosstalk (less than -70dB) but they both measured better than expected (see attached). I used an eBay chassis which is runs at about 60ºC when its 25ºC (I don't recommend this chassis). I used Dale RN55s for the most part and matched the resistors between channels, which helped achieve ~0.1dB channel matching. The unmatched IRFP240s were my leftovers from matching sets for an Aleph J, meaning they were far from being matched. I substituted the 10uF electrolytic coupling cap for a 1uF WIMA and it didn't seem to effect the LF. I used a 4700uF output cap because it was the only kind I had on hand that would fit the board.
I ran a few measurements on an AP with a 1Vrms input, and using 8Ω loads. The amp is biased to 12V.
Thank you Mr. Pass for sharing yet another elegant amp design! And thank you to the diyAudio community for inspiring me to build it.
-Olen
  • Signal to Noise Ratio.pdf
  • ACA Gain.pdf
Very nice. What is underneath the power amp in the second image? Is it a DIY preamp with handles?
I wish it was a DIY creation but it's a Classe Five preamplifier - pretty rare - 1990s version of their old 1980s DR-5. It has all the bells and whistles I need, including a MC head amp, a set of XLR in and out, along with a very heavy remote control.
