Pictures of your diy Pass amplifier
KatieandDad, the mug is isolated
Just finished work
ba3fe Preamp + phono
since the top lid and sides were out for some paint, I used the opportunity to take some pictures. front is 10mm alu, powerbutton is from arcoelectronics and the knobs are fender spare parts. Have I mentioned that I did the metalworks by myself - cutting drilling grinding.....bah!
to the left my F5; to the right Thorens TD166 spezial.
and here!
just finished my preamp. it's up and running hot(class A). A BA3FE clone (layout by Birger Maaß) with psu from same designer plus a phono input device in subchassis by Rod Elliott with its own psu. 3 inputs in total. I've used a simple selector switch an an Alps poti with extensions. All connectors by Neutrik. Main audio ground via groundloopbreaker (bridge+cap+resistor (thanx to ESP)) in the upper left corner. Mainsfilter and powerrelais in lower right position.
as allways the worst thing is the metalworks (hate it!)
My beasts
Here is my beasts 🙂 stereo XA100.5 in XA160.5 enclosure. Wired in pure solid silver,Mundorf Cooper binding posts, cooper rhodium plated IEC sockets etc etc.
Differencies from stock xa.1005 - more beefy powersupply caps,added soft start circuit with 6000W relay, resetable fuse, standby circuit removed,as wel as gain jumper. Also added ability to use direct coupled input (ommiting input caps) when using internal jumpers, front dial circuit is also redesigned/simplified.
How those babies sounds? - one word- Awwwwesooooome!!! 😎
and here!
I like this construction systematic.
A Classic "Attila the Hun" kind.
