Aleph J: Phase 1
I never thought I would be able to do this myself, but it was easier than I had expected. I will have a while to wait to see if I got everything done properly, because I have lots to do before I can test the pcb.
Next phase is the enclosure. I have to figure out how to drill and thread holes in the heat sinks. Never done that before, so should keep me busy for a while.
Your gonna love it. Very romantic amplifier. Still maybe the best I have heard 500hZ and up. Then again, I haevnt heard but a few![]()
I have an original Aleph 3. It is beautiful and is powering mid/hi on my Magnepan MG3A's.
I am looking forward to comparing the Aleph 3 with the Aleph J. I do worry though, that the J might run out of steam. I decided to build to the original J specifications (except slightly higher rails from 21V secondaries). The Maggies are 4 Ohm and the standard J does not like 4 Ohm.
hi and thanks pcb. I dont actually have to much information on the cooling as this was something that was going to get thrown away. it splits into 4 parts and have alot of surface are inide. My colleague told me it was good for about 1000 watts. The plan is to use a fan from this review Recommended Fans | silentpcreview.com , hopefully i can manage to get a tolerable dB level
Very unlikely if you are building something from Nelson Pass.
Sven
Sven
that depends, could be something designed for ~100-150W per channel output, that would need to cope with ~1000W of heat =)
Sven
1000W dissipation is 1000W. no matter if it is pass design or krell or what not.
- Pictures of your diy Pass amplifier
