I'm not sure how that works, I think they are stamped in. Frontpanel express can do them too
http://www.frontpanelexpress.com/products#studs
They are typically called PEM studs or PEM fasteners....and they come in many sizes and shapes to press into different thickness materials and metal/plastic etc.
Technically they are "press-in" fasteners
McMaster-Carr
Nice work. And really, two uses: an amp and a space heater!
Thank you. The black screws are in the mail
Right? Still not as hot as the light bulb MOSFET amp though
Stupendous!
What design is it? Are those 6CL6 output tubes?
It's The Stupendous 6P1P 4PP amplifier!
It uses 8 6P1P triode strapped per channel and makes 8W of class A power.
Simple put, parallel feedback is applied in parallel with input signal (think of inverting amp using opamp, where one resistor goes from the source, another one goes from the output).
Would that include plate to grid (Schade) feedback?
Got them from Triode Electronics TO-9105-1. Very small. But capable. That's the reason I built a RH84. It has some tricks to make a small output transformer sound bigger.Which UGTs are so small that they fit inside?
There is going to be a raspberry pi based volumio with hifiberry dac inside...So an all in one streamer and amp.Damn Bas that was slick but were have you hide the input?
Nice, yes there are lots of new options to connect things and less with cable everywhere.
Specs?A friend of mine finally found the time to build some of the boards i drew back in ''19 for a tube regulated power supply with 3X EL34 or KT88.
More pictures, tube regs are fun
Heres another picture, friend got it to work.
Works well, without any filtering in the supply output noise is measured at around 2mV RMS into a 150mA constant load. With about 5VRMS ripple in.
Could have been better, i designed in a Zener reference that is noisier than a VR tube such as the 85A2
Yes, it is parallel feedback. And it's input resistance similarly to Miller capacitance is calculated as the feedback resistance divided by amplification factor of the stage.
- Tubes / Valves
- Photo Gallery
